Threads: 3
Likes Received: 1 in 1 posts
0 25-Feb-2023, 12:51 PM (This post was last modified: 07-Feb-2024, 01:05 PM by balauru_327.) Hello,
I would like to buy a beginner tiny fpv drone with a camera that has a SD card slot and has an analog transmission . From what I understand Caddx Turtle V2 offer this.
Are there others similar cameras?
Thanks.
Threads: 73
Likes Received: 347 in 260 posts
Likes Given: 157
19 Guess it depends on what you mean by tiny.
Hubsan do (or did, haven't looked recently) a cheap but well made RTF.
There was a micro Eachine AIO Camera/VTX that had MicroSD recording, one of the TX0? range. That could be fitted to most cheap 65/75 quads.
The introduction of cheap (er) HD video has thrown all the cards up in the air currently, that and the electronics shortages.
Threads: 1
Likes Received: 34 in 27 posts
Likes Given: 76
4 If the external recorder does not have a built-in gyroscope, purchase an OpenLogger board to record gyroscope data from the flight controller to an SD card. Data from the gyroscope is needed to stabilize the video in the Gyroflow program.
Threads: 47
Likes Received: 2,798 in 2,259 posts
Likes Given: 7,777
97 Some HappyModel VTXs also have a DVR built in.
Threads: 68
Likes Received: 1,157 in 840 posts
Likes Given: 105
59 There are quite a few choices depending on how "tiny" your drone is and what image quality you are expecting.
The lightest option is DVR on the VTX like Runcam Diamond, but this just records the camera signal at 720p.
Then you have the combined FPV/recording camera boards, I think the lightest one is Runcam Split 3 Lite at around 8g. It records 1080p and has a passable FPV image. I liked this a lot on a 75mm whoop. Similar ones are Caddx Baby Turtle and the Firefly board, and then the larger ones the others have mentioned.
If you can carry a few more grams though, there are some very light external HD cams now like the Runcam Thumb (1080p for 10g) and Thumb Pro (4k for 16g). You will likely get better recorded image quality, these cameras log gyro data so the video files can be stabilized in gyroflow, you can use a good fpv camera and not have to compromise (most split/hybrid cameras have mediocre FPV image, except Tarsier is great but larger and power hungry), you can set the camera exposure settings if you want for different lighting, plus easily movable between drones.
I have quite a few of these split boards I've collected over the years, but these days I don't fly any of them. I'm not sure there is any advantage to them anymore with the compromises.
Threads: 1
Likes Given: 76
4 You probably meant the Runcam Thumb Pro camera (not the Runcam Thumb).
