S800 iNAV rates
So I installed a MATEK F411-WING with iNAV into my S800.
I have passthrough (manual), acro and angle mode on a switch on my TX.
In passthrough / manual mode everything works OK and I can do a roll without issue.
Then I switch to acro mode and I see in the OSD than the mode is indeed changed from MAN to AIR.
Now in this mode I noticed that a roll is much slower.
If searched a lot but I haven't found the correct setting to make it quicker.
I quess it's a 'rate' setting somewhere.
Does anyone know which setting(s) I should look at?
Thanks.
Sorry not an iNav user (yet), I hope someone has the answer.
To answer my own question I solved it by increasing the FeedForward.
I got some help on the INAV Facebook group.
  Inav & Matek jaysbay 4 56 1 hour ago
Last Post: jaysbay
  Best FC for inav or ardupilot? PJKMBAKER 0 528 05-Nov-2023, 12:21 PM
Last Post: PJKMBAKER
  INAV 6 + FLYING WING: ENGINE STARTS AND STOPS, STARTS AND STOPS..... sam26 1 662 08-Sep-2023, 08:19 PM
Last Post: StuweFPV
  Time to prepare the S800 - kaitylynn 39 4,675 14-Nov-2021, 02:36 PM
Last Post: kaitylynn
  S800 build questions ShadowFPV 2 1,297 03-Jul-2019, 04:00 PM
Last Post: ShadowFPV
