03-Jul-2019, 09:37 AM
Hi all,
I read Oscars build log regarding the S800 wing some time ago.
This got me thinking about building one myself.
I already build (and rebuild) 4 quadcopters so I have aquired some building experience in the past 9 months.
I have a FrSky Q X7S with R9.
I selected already most of the components following Oscar's recommendations.
There are however some things that I'm not sure about.
1) I'm thinking of using a micro size camera because those are the ones I already use on my quads.
I tend to use the same components if possible because it's easier keeping spare parts or swapping out stuff.
Question: Is a Micro size easy to mount or would a mini size be better?
2) RX and/or FC
I'm currently undecided on what RX and/or FC I should use.
I would prefer to use an R9 receiver since I have R9 on my TX and it would give me good range.
But I also like the idea of having some sort of autolevel mode.
My quads I fly only in Acro mode and I can fly multiple packs without crashing. So I guess I'm now an OK pilot.
I looked at the following three options.
- R9 Slim+ (Cheapest)
Pro's: Simple and R9 compatible so good range.
Cons: No FC or gyro so no auto level
Question: I think I can connect the servo's and ESC signal line directly to the CH1-3 on the R9 Slim+. Or am I wrong?
- S6R (Mid price)
Pro's: Auto level mode
Con's: 2.4Ghz so less range
- Matek F405-WING + R9MM (Most expensive)
Pro's: Auto level mode (I guess since it's running iNav)
Future proof looking at the number of ports/pads on the Matek.
Con's: Complexity? I'm not familiar with iNav just yet.
Cost
Any ideas, remarks and/or advise is welcome.
Also maybe someone knows a good simulator for me to test wing flying.
Thanks!
2) RX and/or FC
- S6R (Mid price)
Cost
Thanks!
