Rushfpv Blade - flashing - SOLVED
Hello,
I have Rushfpv Blade Stack (for dji) and am experiencing some difficulties.
Main task: I have to reverse 2 motors
1. Connecting to bheli32:
Do not recognize ESCs, and gives message about FC old firmware
First message: found no valid esc configuration
Second message: found outdated 4 way-interface revision
Considering, old firmware is a problem - Updating firmware:
I do not have experience with bootloaders, which is used in this FC.
I have downloaded Zagdig, and insert cable with pressed button.
FC appears as Undefined and I cannot reinstall any driver.
As a conclusion firmware could not be updated as well.
Nithing helps: drivers updates, different pcs, etc….
Could you please advice, what is problem here?
I know there is something very easy.
What is correct sequence of actions in case of bootloader?
P.S. FC connects to betaflight correclty (COM6), motors spinning, all is fine.
have tried 3 different windows PCs
I have investigaet all internet, have seen all videos and solutions.
Just remove all components from fc
As I have mentioned: I have been missing something really minor
  Solved mixer mode problem [SOLVED] Debagle 0 165 20-Jun-2024, 10:07 PM
Last Post: Debagle
  After flashing the ESC using JESC zomer 1 202 18-Sep-2023, 09:50 AM
Last Post: voodoo614
  Flashing custom BF hex file mstc 0 166 11-Jun-2023, 02:54 PM
  Betafpv spi elrs 12a aio bricked after flashing firmware Dronewhooper 14 1,400 04-Feb-2023, 01:03 AM
  Problem with Rush Blade F722 Analog and Telemetry Denethor 7 1,179 10-Dec-2022, 04:37 PM
Last Post: chukaman
