Threads: 3
Likes Received: 4 in 3 posts
0 Hi
does anyone know if the colour of the light should change on my Rush tank VTX if i change the power via smart Audio on 3 of my builds i run 500mw but the light on the vtx is always green for 25mw would be nice to know
Threads: 31
Likes Received: 208 in 158 posts
Likes Given: 95
14 Yes it should. Make sure you have the vtx tables right and also check if you have low level power mode until arm enabled. If it's enabled it will remain at 25w until you arm it. But I would guess that the problem is own the vtx table. Post your table so I can check it for you.
Threads: 3
0 Thanks for the reply I checked when I got home I’ve now set the low power until arm in beta flight but it still a green light once armed I followed a JB video to set up the vtx tables I think it was tbs 2.1 that I uploaded onto it I will try and post the settings once I learned how to ???
Threads: 31
Likes Given: 95
14 It's nice that you turn the low power feature on, it's good for your vtx, but I meant that you could have that on and because of that you were not getting any light than green because the quad was not armed. It's really the vtx tables. Do you have the regular rush vtx? I'll put the code in here, you just have to paste it on cli. Then go to the vtx tab and confirm that everythings is fine. Just confirm the vtx model.
Threads: 3
0 thanks i have some work to do i will check i have the right smart audio selected and Vtx tables i guess i made a mistake when setting up the table i can change channel via smart audio and power level just was not sure it was working due to the light on the vtx always being green for 25mw i have the rush tiny tank on a 3inch build and the rush ultimate on a 5 inch build also have the normal tank on my first build that is running betaflight 3.5 or something and that works fine have it set to 500mw and the light is red on that one many thanks for the help
Threads: 31
Likes Given: 95
14 You can get the json file for your rush from that google drive and import it on the vtx table tab. Hit save and you are good to go. It's easy. There is also some images of this procedure on the same google drive. The led will change, at least on my rush tank ultimate, it changes.
