06-Feb-2020, 02:42 AM
Greetings folks!
I stumbled upon this forum right as I was beginning my latest round of building, so I figured I would document it for all of you to enjoy, given how little I was able to find on the Nano Drak on the forums in general. This is the 28" wingspan version, and I'm building it with the intent of being a general-purpose FPV wing- powerful enough for some screaming fun at the park, but able to cruise fairly efficiently for some longer range exploring and with the FPV and RC equipment to support that. I may even pick up the 40" wings eventually for even more cruising ability, depending on how flying goes in the beginning.
The parts are a mix of stuff I had lying around and some new stuff specifically for this build.
Airframe: RiteWing Nano Drak 28"
Motor: Armattan Oomph Velvet 2205 2250kV
ESC: Hobbyking AeroStar 30A
FC: Matek F411 Wing
Servos: Hitec HS65MG
RC: FrSky R-XSR
Camera: Foxeer Razer Micro
VTx: AKK 5.8GHz 600mW
Antenna: VAS Ion
Props: DAL Cyclone 5x4x3
Battery: 4s 1500mAh 100C
In addition to the stock airframe I'll also be laminating and adding fiber tape for reinforcement in critical areas.
I began the build tonight by gluing in the spar holders and foam spar covers and by going over and smoothing some rough patches on the airframe, as well as adding the fiber tape on the leading edges and the sides and bottom of the fuselage. I will post pictures as the build progresses to more interesting stages!
FC: Matek F411 Wing
RC: FrSky R-XSR
Antenna: VAS Ion
