Threads: 14
Likes Received: 163 in 126 posts
Likes Given: 1
12 It's an odd spacing on these and the frame is designed so a 20x20 doesnt fit. Toothpick 26x26 board might work but these are about the same price and those 1103 motors just don't need any more amps than the TH board supplies. But you will at least have a board for something later if it does work out.
I've been using mine for years though without failure, I don't think this is a common issue if you just replace with stock.
Threads: 14
Likes Given: 1
12 Is that ghost? 900mhz will not like that antenna. Looks way to big to be a 5.8 dipole too.
Threads: 66
Likes Received: 352 in 254 posts
Likes Given: 490
12 Nah its the whip crossfire antenna that comes with the micro receiver.
I just covered it in heat shrink so it didn't get damaged
Threads: 595
Likes Received: 9,039 in 6,690 posts
Likes Given: 1,428
796 Just be cautious with the Minimortal T. I have one but have never fitted it to anything (yet). Trappy himself regularly makes fun of it by saying only to fit one to your quads if you want a failsafe. I have no idea on the range so it might be fine for the sort of distances you do with a micro, but I suggest to take it easy to start with until you understand its actual range capabilities.
Threads: 66
Likes Given: 490
12 Yeah I can't imagine it getting any decent range.
For me its more to be able to have the same receiver on every quad and to give a bit more reliability than the frsky.
I can only see this quad flying a few hundred metres around me.
Threads: 54
Likes Received: 54 in 48 posts
Likes Given: 10
3 Yes, I'm digging up old threads. UrbanJungle, What did you end up using, the Diatone? I am looking for an alternative also. Now i see a thread about the Darwin FPV board..hmm.
Is there a place that makes whoop to 16x16 adapter plates, or is that DIY?
I see you went with Crossfire, what did you use for a VTX? Is the stock 200mw worth reusing?
Thanks!
