20-Dec-2020, 08:41 AM (This post was last modified: 20-Dec-2020, 09:00 AM by iFly4rotors.)
HELP.
While working on my BEAST build, I had soldered the Camera output to the CAM pad on the iFlight BEAST 55A AIO flight controller. I caught the wire on something and pulled the pad from the FC. Although I attempted to repair the pad, that was not successful.
I need to remap a UART pad on the FC for the CAM input.
The attached graphic shows the wiring diagram. As per one of TMac's options for faster satellite acquisition, I am powering the GPS with an external 5V BEC.
TX1-RX1 is at the top right corner above the block of pads. TX2-RX2 is inside the connector where the Rx receiver is wired.
UART1 = Open UART2 = Open UART3 = Rx Receiver UART4 = VTX Tramp/SmartAudio UART5 = is not listed in the Betaflight Ports Tab UART6 = ? Can't find Tx-Rx pads. UART7 = GPS UART8 = ? Can't find Tx-Rx pads.
20-Dec-2020, 11:25 AM (This post was last modified: 29-Dec-2020, 06:01 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" note. )
Unfortunately the camera input can't be remapped because it isn't controlled by and doesn't go through the MCU. If you are unable to locate / scrape back the trace that went to the CAM pad then your only other option is to direct solder a wire to the appropriate pin on the OSD chip. This is the large rectangular 28-pin MAX7456 chip on the board next to the grey inductor with "100" written on it. On the iFlight Beast H7 55A AIO they use a Chinese clone of that chip called the AT7456E but it has exactly the same pinout as a MAX7456. See the image below.
You need to solder to pin #22 (VIN). EDIT: Please see the correction in post #5.
Yes, that's the correct chip. One correction however is that you won't be soldering directly to pin #22, but instead to the other side of a 0.1uF capacitor which is connected to that pin. So you need to trace which capacitor on the board has continuity from one side of it with pin #22 on the AT7456E ISD chip. You then need to solder to the other side of that capacitor. It's likely to be one of the capacitors (beige coloured components) close to the OSD chip.
21-Dec-2020, 02:04 PM (This post was last modified: 21-Dec-2020, 04:06 PM by SnowLeopardFPV. Edit Reason: Corrected resistor value. )
If you connect to the VIN pin (pin #22) on the AT7456E OSD chip, in addition to the 0.1uF capacitor, you are also going to need to add a 75Ω resistor to ground. So you will effectively have to replicate that sub-circuit off the board. Below is a magnified area of the circuit for the MAX7456 / AT7456E that you will need to rebuild off the circuit.
(21-Dec-2020, 02:04 PM)SnowLeopardFPV Wrote: If you connect to the VIN pin (pin #22) on the AT7456E OSD chip, in addition to the 0.1uF capacitor, you are also going to need to add a 75k resistor to ground. So you will effectively have to replicate that sub-circuit off the board. Below is a magnified area of the circuit for the MAX7456 / AT7456E that you will need to rebuild off the circuit.
Hi Snow,
Presumably, I can ground it to any ground pad on the FC.
Ok, one more question {I think}. The CVBS IN; is that just where the video input {wire} connects? The diagram also shows a ground there, but is that ground just for sheilding on the input? So, I don't need to ground at that point since I will only have a single wire attaching to that part of the circuit?
I have already found a source for the capacitor and the resistor. I am waiting on some 40 gauge magnet wire to use for the connection to the pin on the OSD chip. Now, I am looking for a small circuit board for that assembly rather than just leave things hanging.
This looks more and more like the best workable solution.
I REALLYappreciate your help on this. You areAMAZING
Please note that I corrected my previous post where I inadvertently typed 75k instead of 75Ω. That now reads correctly.
You can connect the other side of the resistor to any ground pad on the FC. The ground for CVBS IN is just the shielding as you already suggested so you don't need to worry about that. Just twist the ground and signal wire from the camera together (twisted pair) which will help to mitigate any external interference on the signal wire.
Obviously it goes without saying that you need to be really careful soldering a wire to that pin because the pin next to it (pin #21) is supplied with 5V so you want to try and avoid shorting that to the VIN pin because it may not tolerate 5V being injected into it.
(21-Dec-2020, 04:33 PM)voodoo614 Wrote: I wonder if the resistor is the one left of the T4 pad in your photo? Can you get in there?
Hi voodoo,
No, don't think I can, even with a "needle" tip on the iron. It is just too small of a space and too tiny of a component. I can barely see it even with +6.0 reading glasses. Although it looks pretty big in that pic, fact is that image is zoomed in quite a bit; both optically with the camera and then again with the graphic software.
In fact, the largest thing that I have available is the actual pin on the OSC chip; yeah, even that is pretty tiny. I might actually have to buy a microscope in order to work on this thing.
Having examined the board every which way with my +6.0 glasses and using optical and software magnification, I believe the best approach is to build the additional circuitry and connect it directly to Pin 22 on the OSD chip. Probably, my best chance at success.
I really appreciate all of your help and suggestions.
