10-Nov-2022, 02:10 PM (This post was last modified: 17-Mar-2023, 06:25 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. )
EDIT (18th January 2023): IMORTANT PSA -> For anyone who has one of either the RadioMaster Ranger Micro or Nano modules (not the 2W flagship OLED module), please be sure to read the PSA that has been posted in another thread HERE.
RadioMaster have just released (for pre-order) a new ExpressLRS module which is capable of outputting 2W of power. From the factory it comes marketed as and locked to 1W for legal reasons but with a built in "hack" you can unlock it for 2W (see Wezley Varty's video after the product images in this post for how to do that). Orders will start shipping in December 2022.
EDIT: Due to Wezley Varty being investigated by CASA (see another post HERE), he's unfortunately taken down most of his videos including the one showing how to perform the 2W hack. To apply the hack you need access the web interface of the module by connecting to http://10.0.0.1/hardware.html. You then need to set High Power to 2000mw, Max Power to 2000mw, and set the last zero of Level Values to 2.
As well as the full size module with the OLED display on it, there are also smaller Micro and Nano versions available with no OLED display.
Any related videos are all linked to at the end of this post.
RadioMaster Web Shop Links:
Description:
The RadioMaster Ranger is the pinnacle of ExpressLRS module design. Built not only to look great but to last with its rugged CNC machined aluminum case that aids the high-efficiency cooling system as a heat sink. The Ranger is up to any task and provides all the power and functionality you need.
Featuring an OLED display, a directional menu key, and two assignable shortcut keys the Ranger can be adjusted on the fly and personalized to your needs.
The Ranger includes a T Antenna for general use and a RadioMaster Moxon antenna for long-range directional applications. A micro module and nano module adapter are included to ensure the Ranger is compatible with most radios on the market today. A cable has also been included for use with Futaba radios that are CRSF capable.
Except for the Ranger, we also provide the Ranger Micro and Ranger Nano for your choice.
Features:
Official RadioMaster Marketing Video:
How to hack the RadioMaster Ranger ELRS module to 2W:
Review / Overview Videos:
- Full Size OLED Ranger 2.4GHz ELRS Module ($99.99 USD): https://www.radiomasterrc.com/collection...lrs-module
- Ranger Micro 2.4GHZ ELRS Module ($39.99 USD): https://www.radiomasterrc.com/collection...lrs-module
- Ranger Nano 2.4GHZ ELRS Module ($39.99 USD): https://www.radiomasterrc.com/collection...lrs-module
Description:
Features:
- OLED Display
- Rugged CNC Case
- Built-in Accelerometer
- Packet rates up to F-1000Hz
- Up to 1 Watt Power output
- Wifi and Bluetooth support
- High-efficiency cooling system
- 5 Direction Nav key and customizable shortcut buttons
- Micro and Nano adapters included
- Moxon and T-antenna included
- CRSF cable for compatible Futaba radios included
- Item: Ranger 2.4GHz ELRS Module
- Regulatory Domain: ISM2400
- MCU: ESP32(main), ESP8285(aux, as ESP backpack)
- RF chip: SX1281IMLTRT
- Frequency Range: 2400 MHz - 2480 MHz
- Maximum packet rate: 500Hz/F-1000Hz (F-1000Hz mode requires EgdeTX 2.7.1 or later)
- Minimum receiver refresh rate: 25Hz
- RF Output Power: 30dBm for FCC, 20dBm for CE (Adjustable by LUA)
- Module bay adapters: JR standard 5pin socket & Nano standard 8pin socket
- Futaba CRSF socket cable: Included
- OLED screen: 64x128px
- Wifi Support: Yes
- Bluetooth support: Yes
- 3-Axis Accelerometer: Yes (STK8BA58 MEMS Accelerometer)
- Built-in RGB light strip
- XT30 Power supply voltage: DC 6V - 16.8V
- Weight: 138g (with Moxon antenna) / 135g (with T antenna) / 126g (without antenna)
- Dimension: 95*51*25mm (without antenna)
- 1 * RANGER Module
- 1 * Futaba CRSF socket cable
- 1 * JR Adapter
- 1 * Nano Adapter
- 1 * T Antenna
- 1 * Moxon Antenna
- 1 * Hexagon socket screwdriver
- 3 * M2*5 Screws
- 1 * Assembly Manual
