13-Apr-2024, 12:37 PM (This post was last modified: 19-May-2024, 12:34 AM by SnowLeopardFPV. Edit Reason: Added "Edit" line. )
EDIT (19th May 2024): The final release of ExpressLRS v3.4.0 is now available. See another thread HERE for details.
The first release candidate of ExpressLRS 3.4.0 was published an hour ago. Keep in mind that this isn't a final release so there are likely still bugs present, so only install release candidate versions if you are happy to be a beta tester and take the risk of having an unexpected failure. Full details are below.
For details about what was in the previous 3.3.2 release, see another thread HERE.
EDIT (22nd April 2024): ExpressLRS 3.4.0-RC2 was published a couple of days ago. Details for the new RC2 release are below.
EDIT (28th April 2024): ExpressLRS 3.4.0-RC3 was published a hour ago. Details for the new RC3 release are below.
Relevant Links:
Changes to RC2 since RC1
Relevant Links:
- GitHub Release Page for ELRS 3.4.0-RC3: https://github.com/ExpressLRS/ExpressLRS.../3.4.0-RC3
- Getting Started 3.x.x Documentation: https://www.expresslrs.org/3.0/quick-sta...ng-started
- Latest ExpressLRS Configurator: https://github.com/ExpressLRS/ExpressLRS...r/releases
Quote:The important stuffCompatibility
- Arming must be on AUX1 for safety and feature reasons, having this fixed allows us to maintain small packet sizes and deliver better aux channel options
- Be sure to flash both the TX and RX.
- This is a release candidate. We have tested it using our release test plan, but there may still be bugs. Don't flash it to anything important. We appreciate the community testing.
- Lua script MUST be updated to elrsV3.lua and is backwards compatible with 2.x. Firmware get it here: Lua
This is a feature release version (meaning it contains new features, targets and bug-fixes) and is compatible with all V3.X versions.
Who should update from V3.3?Who should NOT update from V3.3?
- Our 3 LBT users
- Anyone who is interested in the latest and greatest features listed below
Our STM32 users. This includes the Happymodel ES915 TX/RX, Happymodel PP, NamimnoRC V1 Flash/Voyager TX/RX, FM30, Ghost and FrSky R9 hardware.
New Features
More detail on the below features will be added with coming RCs and the final release.
Team Race "Match TX" output power Added US433 domains Sentinel tracker integration Move targets to separate repositoryAdded serial protocols on receivers ESP32-S3 target support
- #2400 This allows the dev team to add new targets as soon as they have been tested/passed, if they don't require firmware changes to support them
PWM extensions
- #2410 Support for ESP32-S3 targets
- #2463 Get thermal info from S3 if no LM75A
- #2472 Fix esp32s3 and backpack passthrough flashing settings
- #2494 Allow flashing of the backpack on S3 via USB
OLED/TFT menu updates UDP/WiFi Joystick support
- #2346 DShot output for PWM receivers
- #2425 Configurable I2C pins for PWM capable (ESP32) receivers
- #2535 PWM failsafe modes, like no-pulse, hold, and custom set position
- #2624 WebUI: prevent multiple I2C SCL/SDA selections
SPI VTx control
- #2444 Adds a Joystick that sends data via UDP/WIFI
Better binding experience
- #2515 VTX SPI output calibration routine and initial PWM value config
- #2583 Fixed VTX PWM array initialization for unified ESP32 targets
Support for non-EdgeTX handsets Support for Semtech LR1121 dual-band radio
- #2542 Allow all binding methods on RX
- #2523 Support CRSF bind command from betaflight
- #2424 RX remembers last packet rate on disconnect for faster connect
Fix for LBT telemetry lost
- #2540 Gemini Xrossband (GemX) - LR1121 Driver
- #2616 Adds LR1121 image calibration
- #2617 Fix LR1121 binding (adds 2.4GHz binding)
- #2618 Allow choosing the domain for LR1121 modules
Support for BMP280/BME280 I2C barometers on receivers
- #2643 LBT - Change TX modules to use RX mode with timeout
New Targets
- #2480 Add BMP280/BME280 I2C barometer support
With the separation of the targets from the main firmware repository we will list only those targets that are only supported from this release onwards.
Any new targets that have been added that can be supported by older firmware will just show up in Configurator.
TransmittersMaintenance
- Add ESP8285 900MHz TX Target #2566
Fixes
- Allow SPI VTx operation without an FC, for use with planes/cars etc that do not use a flight controller #2316
- Display a logo on OLED/TFT boot #2322
Known Issues
- Fix backpack on Gemini 900 target #2323
- Disable MSP VTx after no comms on boot #2324
- Bring back full 16 Channel support #2365
- Work around hardware bug in ESP32-S3 SPI implementation for SPI connected VTx #2406
- Add float support to Lua #2415
- Fix Lua for SELECT types with only one value #2416
- Various web UI fixes and improvements #2422
- Hide lua backpack items if the backpack is disabled #2429
- SUMD not working at packet rates above 100Hz #2478
- Pin AsyncTCP to a specific version (The upstream released a broken version!) #2522
- Allow screen rotation for TFT screens #2520
- Disable processing MSP VTX commands if there is no SPI VTx #2525
- Pick SSID with strongest RSSI in mesh networks with multiple identical SSIDs #2536
- Allow setting the destination for CRSF MSP packets (fixes integration with rotorflight) #2550
- Fix error when radio chip failed to read #2567
- Update the wifi power levels #2568
- Only call servo function if theres a change #2571
- PWM testing/fixes #2588
- Increase SX1276 SyncPktIntervalDisconnected for 25Hz #2589
- Add file drag-and-drop to web UI update tab #2590
- Pass through handset channels if headtracking switch is off #2615
- Fix "Not set" UID badge in web UI #2619
- Fix antenna value for Diversity/Gemini receivers #2622
- Some STM32 hardware is currently not compatible with v3.4.
- Fixes HoTT Telemetry requiring an external diode #2658
- Debounce BOOT0 readout in the hot loop #2633
- Fix for TBS Tango 2 display #2661
- Save our help-and-support bretheren #2659
- Fix LBT TLM #2660
- add padding to buffer #2666
- WORD_PADDED was returning number of words not bytes #2664
- adds previousMean() to MeanAccumulator #2663
- S3 flash fix for binary_flasher #2665
- Hide button color editors in web UI #2668
- Add missing LNA gain to the hardware.html page #2670
- Fix TX logging with I2C #2675
- Fix boot-loop when no hardware definition uploaded #2674
- LBT 50hz RSSI settling time #2672
- Wait for multiple errors before stopping the wifi joystick #2680
- Reset LQ to 100% on packet rate cycling #2682
- Fix PWM issue of esp8266 device when duty is 0 #2684
