12-Oct-2021, 07:50 PM
Hi!
this is my first build and I am having trouble with the radio input. I am using a spektrum NX6 with a TBS crossfire v2 plugged into the serial port however I cannot get any input coming through to the drone or beta flight. I have looked through everything I could find and have still found no solution
# diff all
###WARNING: NO CUSTOM DEFAULTS FOUND###
# Betaflight / STM32F405 (S405) 4.2.4 Oct 20 2020 / 08:18:45 (fbcaf8c50) MSP API: 1.43
###ERROR: diff: NO CONFIG FOUND###
# start the command batch
batch start
defaults nosave
board_name MAMBAF405US_I2C
manufacturer_id DIAT
mcu_id 003600585553501920323156
signature
# name: Jae Keezy
# resources
resource BEEPER 1 C13
resource MOTOR 1 A09
resource MOTOR 2 A08
resource MOTOR 3 C09
resource MOTOR 4 C08
resource LED_STRIP 1 B03
resource SERIAL_TX 1 B06
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 C06
resource SERIAL_RX 1 B07
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource I2C_SCL 1 B08
resource I2C_SDA 1 B09
resource LED 1 C15
resource LED 2 C14
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource ADC_BATT 1 C01
resource ADC_RSSI 1 C02
resource ADC_CURR 1 C03
resource PINIO 1 B00
resource FLASH_CS 1 A15
resource OSD_CS 1 B12
resource GYRO_EXTI 1 C04
resource GYRO_CS 1 A04
# timer
timer B09 AF3
# pin B09: TIM11 CH1 (AF3)
timer A09 AF1
# pin A09: TIM1 CH2 (AF1)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer B08 AF2
# pin B08: TIM4 CH3 (AF2)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
# dma
dma ADC 3 0
# ADC 3: DMA2 Stream 0 Channel 2
dma pin A09 0
dma pin A08 0
dma pin C09 0
dma pin C08 0
dma pin B08 0
dma pin B03 0
feature RX_SERIAL
feature TELEMETRY
feature OSD
# map
map TAER1234
led 0 14,12::C:1
led 1 15,12::C:1
led 2 14,13::C:1
led 3 15,13::C:1
led 4 14,14::C:1
led 5 15,14::C:1
led 6 14,15::C:1
led 7 15,15::C:1
# master
set acc_calibration = 8,0,166,1
set baro_bustype = I2C
set baro_i2c_device = 1
set fpv_mix_degrees = 15
set serialrx_provider = CRSF
set adc_device = 3
set dshot_burst = ON
set motor_poles = 12
set vbat_warning_cell_voltage = 370
set current_meter = ADC
set battery_meter = ADC
set ibata_scale = 80
set beeper_inversion = ON
set beeper_od = OFF
set yaw_motors_reversed = ON
set osd_warn_rssi = ON
set osd_warn_link_quality = ON
set osd_warn_over_cap = ON
set osd_tim1 = 2561
set osd_vbat_pos = 2064
set osd_link_quality_pos = 2048
set osd_rssi_dbm_pos = 2052
set osd_tim_1_pos = 2552
set osd_remaining_time_estimate_pos = 2540
set osd_flymode_pos = 2534
set osd_throttle_pos = 396
set osd_crosshairs_pos = 2253
set osd_ah_sbar_pos = 2254
set osd_ah_pos = 2126
set osd_current_pos = 2057
set osd_compass_bar_pos = 2282
set osd_battery_usage_pos = 2065
set osd_disarmed_pos = 2219
set osd_core_temp_pos = 2528
set osd_stick_overlay_left_pos = 2368
set osd_stick_overlay_right_pos = 2391
set osd_displayport_device = MAX7456
set enable_stick_arming = ON
set max7456_spi_bus = 2
set pinio_config = 129,1,1,1
set pinio_box = 0,255,255,255
set flash_spi_bus = 3
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_align_yaw = 1800
set name = Jae Keezy
profile 1
profile 2
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
# save configuration
save
