02-Dec-2019, 03:48 AM
Hi all,
I am about to start a new build and I want to use the r9m system from FrSky. I have one of the first r9m modules (not the 2019) and a r9mm receiver (not the OTA verison). For Flight controller I am using a Mamba F405. After having a look at the receiver I see the following pads:
* SBUS_Out
* S PORT / F PORT
* GROUND
* V IN
* Inverted S Port
I would like to try Fport as I don´t have much UARTs available and I want to use a GPS also. My question is if "Inverted S Port" pad is also an inverted F Port pad after flashing the corresponding FPORT firmware to the receiver?. If so:
1. does that mean that I can connect the receiver to my FC with just a cable from "Inverted S Port" to TX1 on the FC?
2. is there something I should change in BF to tell the FC that I am using an uninverted FPORT signal?
I hope to be clear enough with my question.
thanks for any advice
* SBUS_Out
* S PORT / F PORT
* GROUND
* V IN
* Inverted S Port
