Quad shaking during throttle
Hey guys - been flying for about 6 mo.  Stumped on this issue.
Drone has been flying fine for a while, but then I crashed it hard into a bench.
Now, it shakes during throttle. Motors super hot after flying.
Two motors were not spinning smoothly after the crash, so I replaced both esc's, and now they spin smoothly on arm, but same issue while flying where it shakes during throttle and sounds really off.
 Any ideas on troubleshooting this?
Also - here is a video (my camera isn't at the right angle but you can see the shake)
https://drive.google.com/file/d/1jBo3MlN...sp=sharing
5 inch quad, mattek f722-se.
Check for broken arm or loose arms.
It could also mean the shafts are bent or the bearings or bells are damaged. Either of these could cause problems.
Loose arm.
or loose mounting bolts on the FC
(28-Jun-2021, 04:27 AM)voodoo614 Wrote: Check for broken arm or loose arms.
All arms are on their securely. I was reviewing the issue, is it possible the gyroscope is damaged? If so, I have a double gyro board, how would i eliminate the broken one?
Also, if the motor is broken how would I know which one?
(28-Jun-2021, 02:08 PM)Remi Wrote: All arms are on their securely. I was reviewing the issue, is it possible the gyroscope is damaged? If so, I have a double gyro board, how would i eliminate the broken one?
The FC likely use one gyro. You just need to switch to the second gyro through CLI.
set gyro_to_use = second
Save
To check motor. Take props off. Individually spin them and see if you can see any problem. You might not see any problem.
(28-Jun-2021, 05:07 PM)voodoo614 Wrote: The FC likely use one gyro. You just need to switch to the second gyro through CLI.
Save
I switched onto the second gyro, and took the drone out for a test flight, and the same issue happened. When plugging it back in for a second test flight, the drone smoked and I immediately unplugged it. I then brought it home, installed the blackbox and configured it at 500 hz, as that's the highest it goes too, and tried to figure out the shorting issue with my multimeter. As far as I can tell, it only smokes when the top of the frame is on it, (I have tbs source one) so something must be touching the frame. I got halfway through untaping the escs, when I just gave up for the night. Any help would be highly appreciated.
(29-Jun-2021, 01:29 PM)Remi Wrote: I switched onto the second gyro, and took the drone out for a test flight, and the same issue happened. When plugging it back in for a second test flight, the drone smoked and I immediately unplugged it. I then brought it home, installed the blackbox and configured it at 500 hz, as that's the highest it goes too, and tried to figure out the shorting issue with my multimeter. As far as I can tell, it only smokes when the top of the frame is on it, (I have tbs source one) so something must be touching the frame. I got halfway through untaping the escs, when I just gave up for the night. Any help would be highly appreciated.
Why will it only smoke with the top of the frame on? That would be the least possible cause because the only thing most people have mounted on the top plate is a lipo and maybe a Gopro.
I have a SourceOne V3 and that design has so much space to accommodate components that it makes me love my SourceOne every time I take the top plate off. If you have a short on such a frame, then that's not right.
There must be something in the wiring. maybe a screw touching a solder pad, or a solder ball causing a short, maybe a bare wire, check the plugs on the vtx or camera or any other harness plugs for any burn marks. Any components mounted or stacked with little gap or maybe using just double sided tape?
(29-Jun-2021, 03:15 PM)kafie1980 Wrote: There must be something in the wiring. maybe a screw touching a solder pad, or a solder ball causing a short, maybe a bare wire, check the plugs on the vtx or camera or any other harness plugs for any burn marks. Any components mounted or stacked with little gap or maybe using just double sided tape?
There was an esc with vbat on the mounting holes that is only safe to use with rubber grommets. Maybe thats the reason
i had such esc s in the past, bottom carbon was enough contact in my case. the top shouldnt make a difference there.
(29-Jun-2021, 03:15 PM)kafie1980 Wrote: Why will it only smoke with the top of the frame on? That would be the least possible cause because the only thing most people have mounted on the top plate is a lipo and maybe a Gopro.
Hello everyone. The shorting issue was caused by a screw too big touching the capacitor. I then hooked the motors up to betaflight, and a weird thing happened. The motors were fine, but when motor 4 was suddenly put at a range between 1400-1500, it would make a ticking sound. I swapped motor 1(which is fine) and motor 4, which is the bad one. The problem still persisted. (See video which was taken after the swap.) It must be the board as the esc was recently replaced. https://drive.google.com/file/d/1g1jnzZg...sp=sharing
Hi guys, thanks for helping so far.
I took the drone out for a test flight today, and recorded the blackbox. I was hopeful it would be fixed, but same problem. Can anyone read this blackbox file and determine the problem? (Exported video and log file from blackbox configurator here https://drive.google.com/file/d/1CsfPrky...sp=sharing) (Log file from drone here https://drive.google.com/file/d/1URfm-GW...sp=sharing).
  Help over 40% throttle motor1 spin up endless ap79 10 212 14-May-2024, 04:32 PM
Last Post: segler999
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 1,085 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
  Solved Prop noise when releasing throttle skamtastik 6 344 28-Jul-2023, 12:43 AM
Last Post: skamtastik
  Yaw twitch on throttle punch Daniel_BR 24 1,400 29-Jun-2023, 06:38 AM
  Motors spinning up no throttle. Flybyjim 4 657 25-Jun-2023, 08:58 PM
Last Post: Daniel_BR
