20-Dec-2018, 11:15 PM
So I, like many here, have purchased a mobula 7. My immediate instinct was to update the betaflight firmware, so i don't know if having done that is the cause or not. But whenever I fly 1s it just instantly gives a long beep and telling me the battery is dead even though I can fly it. I tweaked it in betaflight so it doesn't beep at all until critically low, and lowered the warning voltage to get the beeping down to a reasonable level, but it still displays an empty battery on the OSD from the beginning until I've whooped around for more than a couple minutes and it warns me it's close as any drone should.. Is there a proper power setting in betaflight to give it a more accurate battery capacity readout for 1s? It works perfectly fine with 2s.
