Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 22-Sep-2021, 03:34 PM (This post was last modified: 22-Sep-2021, 03:35 PM by Fabiansendefpv.) In first place, sorry for my english, Im spanish and not talk english. And... I buyed that a month ago but I have some issues... The drone hasn't strenght, I take the throttle on 70-80% all time to a normal flight and the battery (4s 850mah) dischargue in 2 minuts. I tried mount a full go pro 6 but it can't take off. I'm desperate, any solutions? • Posts: 6,113 Threads: 172 Likes Received: 2,287 in 1,834 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 100 take care about the rotor orientation, as it is a pusher quad the rotors need to be mounted upside down. this would be a common beginner fault on a pusher. if you arent sure about, post a picture for double check. • Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 (22-Sep-2021, 04:10 PM)hugnosed_bat Wrote: take care about the rotor orientation, as it is a pusher quad the rotors need to be mounted upside down. this would be a common beginner fault on a pusher. if you arent sure about, post a picture for double check. Hi, thanks for the response, I put the props as in the picture, are the props ok? • Posts: 6,113 Threads: 172 Likes Received: 2,287 in 1,834 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 100 • Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 22-Sep-2021, 08:54 PM (This post was last modified: 22-Sep-2021, 08:55 PM by Fabiansendefpv.) (22-Sep-2021, 04:25 PM)hugnosed_bat Wrote: https://intofpv.com/t-how-to-upload-pictures i cant see a picture, see the link above Sorry, I wrote from the mobile… Can you see them now? • Posts: 6,113 Threads: 172 Likes Received: 2,287 in 1,834 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 100 i can see one picture :-) its difficult to see the shape some other pictures? it seems the are mounted the rightway "The drone hasn't strenght, I take the throttle on 70-80% all time to a normal flight and the battery (4s 850mah) dischargue in 2 minuts." is this without a gopro? what battery do you use, brand? c-rating? • Posts: 209 Threads: 30 Likes Received: 41 in 35 posts Likes Given: 97 Joined: Nov 2018 Reputation: 1 22-Sep-2021, 09:46 PM (This post was last modified: 22-Sep-2021, 10:20 PM by sircolin.) Hmm not sure it can carry a go pro can it ? I have a smo 4k on mine. My props on my pavo 30 don't look like that ! here's what mine look like ! pavo 30 and get rid of that rubbish vtx antenna ;-) I hope this helps, Chris Rosser also done an amazing tune on this quad once you have it going you should check it out on youtube. Col Youtube A Mistake is only a Mistake if you refuse to correct your error. Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 • Posts: 209 Threads: 30 Likes Received: 41 in 35 posts Likes Given: 97 Joined: Nov 2018 Reputation: 1 (22-Sep-2021, 09:54 PM)Fabiansendefpv Wrote: Yeah, two minuts without go pro, the drone cant take off with go pro.. I buyed 4s 75c 850mah from betafpv, I seen in blogs the normal duration its about 7-8 minuts without go pro 850mah will is what i fly with and i do get those flight times, From what i can see your props are in the wrong direction to mine maybe try to make them match mine and see what happens the worst case will be i flips over and don't fly. Was this a bnf or did you build it ? Looking at where i brought mine from i see props out! pavo 30 Col Youtube A Mistake is only a Mistake if you refuse to correct your error. • Posts: 6,113 Threads: 172 Likes Received: 2,287 in 1,834 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 100 about the motor trust and battery, the quad should be easily able to hoover with a gopro... just hoover for sure, not that it would be enjoy or usable... even this can lift a fullsize gopro xD im realy sorry, i look at it seems minutes but i cant see it the round shape must be on top - like on this picture: • Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 (22-Sep-2021, 09:46 PM)sircolin Wrote: Hmm not sure it can carry a go pro can it ? I have a smo 4k on mine. My props on my pavo 30 don't look like that ! here's what mine look like ! pavo 30 and get rid of that rubbish vtx antenna ;-) I hope this helps, Chris Rosser also done an amazing tune on this quad once you have it going you should check it out on youtube. Col Thanks for the response and the recomendation, I will see this video now: I have a lot of jello... Have you the name of a good vtx antenna? And... I think I have the props wrong. Tomorrow I check that on the field • Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 (22-Sep-2021, 10:23 PM)hugnosed_bat Wrote: about the motor trust and battery, the quad should be easily able to hoover with a gopro... just hoover for sure, not that it would be enjoy or usable... even this can lift a fullsize gopro xD im realy sorry, i look at it seems minutes but i cant see it the round shape must be on top - like on this picture: Its so difficult watch good the props angle hahaha And...a lot of thanks! I think I putted the props wrong, tomorrow I check it on the field • Posts: 209 Threads: 30 Likes Received: 41 in 35 posts Likes Given: 97 Joined: Nov 2018 Reputation: 1 Your more than Welcome, That video changed how this quad fly almost 100%, No jello and a full throttle gives me full throttle it didn't before. I don't have the good name of a VTX antenna because my way way to use a UFL to SMA adapter and use a menace short Sma RHCP with a right angle it holds just fine when flying but i really need to think about some hot glue or something it does move a little. Good luck tomorrow and if it still not working post back here. Col Youtube A Mistake is only a Mistake if you refuse to correct your error. • Posts: 23 Threads: 6 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Jul 2021 Reputation: 0 (22-Sep-2021, 10:33 PM)sircolin Wrote: Your more than Welcome, That video changed how this quad fly almost 100%, No jello and a full throttle gives me full throttle it didn't before. I don't have the good name of a VTX antenna because my way way to use a UFL to SMA adapter and use a menace short Sma RHCP with a right angle it holds just fine when flying but i really need to think about some hot glue or something it does move a little. Good luck tomorrow and if it still not working post back here. Col I changued the props and cant take off :/ Now I have the props same as the picture: But the drone cant fly, the motors rotate with power but not take off. I checked the accelerometer, position and all is good Thanks for all support • Posts: 209 Threads: 30 Likes Received: 41 in 35 posts Likes Given: 97 Joined: Nov 2018 Reputation: 1 23-Sep-2021, 05:27 PM (This post was last modified: 23-Sep-2021, 05:27 PM by sircolin.) Hi Fabiansendefpv, Ok lets check your motor direction setup in betaflight go to the configuration tab and make a note of motor directions is the motor direction reversed ? next go to the motor's tab in betaflight with your props OFF (just in case) We dont work on quads with props on, on the bench. Make sure you have a battery installed and one by one raise the motor sliders and confirm your props are spinning in the direction that were on the configuration tab. and report back. Keep your props off for now until we resolve this. Youtube A Mistake is only a Mistake if you refuse to correct your error. • |
