26-Mar-2022, 06:17 AM
Osd question
OSD won't show in DJI Goggles V2
Hello,
I am looking for assistance with my new drone build. My OSD won't show the battery voltage or another information when connected. I made sure it was wired correctly. Below is the "Dump" from the CLI command. Any help is greatly appreciated
Entering CLI Mode, type 'exit' to return, or 'help' #
\# Building AutoComplete Cache ... Done!
\# dump
\###WARNING: NO CUSTOM DEFAULTS FOUND###
\# version
\# Betaflight / STM32F7X2 (S7X2) 4.2.6 Jan 5 2021 / 19:08:42 (a4b6db1e7) MSP API: 1.43
**###ERROR: dump: NO CONFIG FOUND###**
\# start the command batch
batch start
board\_name FLYWOOF7DUAL
manufacturer\_id FLWO
\# name: test
\# resources
resource BEEPER 1 C14
resource MOTOR 1 B01
resource MOTOR 2 B04
resource MOTOR 3 B03
resource MOTOR 4 A15
resource MOTOR 5 C08
resource MOTOR 6 C09
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 C06
resource PWM 1 B10
resource PWM 2 A02
resource PWM 3 A03
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource SONAR\_TRIGGER 1 NONE
resource SONAR\_ECHO 1 NONE
resource LED\_STRIP 1 A08
resource SERIAL\_TX 1 A09
resource SERIAL\_TX 2 A02
resource SERIAL\_TX 3 B10
resource SERIAL\_TX 4 A00
resource SERIAL\_TX 5 C12
resource SERIAL\_TX 6 C06
resource SERIAL\_TX 7 NONE
resource SERIAL\_TX 8 NONE
resource SERIAL\_TX 9 NONE
resource SERIAL\_TX 10 NONE
resource SERIAL\_TX 11 NONE
resource SERIAL\_TX 12 NONE
resource SERIAL\_RX 1 A10
resource SERIAL\_RX 2 A03
resource SERIAL\_RX 3 B11
resource SERIAL\_RX 4 A01
resource SERIAL\_RX 5 D02
resource SERIAL\_RX 6 C07
resource SERIAL\_RX 7 NONE
resource SERIAL\_RX 8 NONE
resource SERIAL\_RX 9 NONE
resource SERIAL\_RX 10 NONE
resource SERIAL\_RX 11 NONE
resource SERIAL\_RX 12 NONE
resource I2C\_SCL 1 B06
resource I2C\_SCL 2 NONE
resource I2C\_SCL 3 NONE
resource I2C\_SCL 4 NONE
resource I2C\_SDA 1 B07
resource I2C\_SDA 2 NONE
resource I2C\_SDA 3 NONE
resource I2C\_SDA 4 NONE
resource LED 1 C15
resource LED 2 NONE
resource LED 3 NONE
resource RX\_BIND 1 NONE
resource RX\_BIND\_PLUG 1 NONE
resource TRANSPONDER 1 NONE
resource SPI\_SCK 1 A05
resource SPI\_SCK 2 B13
resource SPI\_SCK 3 C10
resource SPI\_SCK 4 NONE
resource SPI\_MISO 1 A06
resource SPI\_MISO 2 B14
resource SPI\_MISO 3 C11
resource SPI\_MISO 4 NONE
resource SPI\_MOSI 1 A07
resource SPI\_MOSI 2 B15
resource SPI\_MOSI 3 B05
resource SPI\_MOSI 4 NONE
resource CAMERA\_CONTROL 1 B08
resource ADC\_BATT 1 C01
resource ADC\_RSSI 1 C02
resource ADC\_CURR 1 C00
resource ADC\_EXT 1 NONE
resource BARO\_CS 1 NONE
resource BARO\_EOC 1 NONE
resource BARO\_XCLR 1 NONE
resource COMPASS\_CS 1 NONE
resource COMPASS\_EXTI 1 NONE
resource SDCARD\_CS 1 NONE
resource SDCARD\_DETECT 1 NONE
resource PINIO 1 B00
resource PINIO 2 B09
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB\_MSC\_PIN 1 NONE
resource FLASH\_CS 1 C13
resource OSD\_CS 1 B12
resource RX\_SPI\_CS 1 NONE
resource RX\_SPI\_EXTI 1 NONE
resource RX\_SPI\_BIND 1 NONE
resource RX\_SPI\_LED 1 NONE
resource RX\_SPI\_CC2500\_TX\_EN 1 NONE
resource RX\_SPI\_CC2500\_LNA\_EN 1 NONE
resource RX\_SPI\_CC2500\_ANT\_SEL 1 NONE
resource GYRO\_EXTI 1 C03
resource GYRO\_EXTI 2 C04
resource GYRO\_CS 1 A04
resource GYRO\_CS 2 B02
resource USB\_DETECT 1 NONE
resource VTX\_POWER 1 NONE
resource VTX\_CS 1 NONE
resource VTX\_DATA 1 NONE
resource VTX\_CLK 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
\# timer
timer C06 AF3
\# pin C06: TIM8 CH1 (AF3)
timer B01 AF2
\# pin B01: TIM3 CH4 (AF2)
timer B04 AF2
\# pin B04: TIM3 CH1 (AF2)
timer B03 AF1
\# pin B03: TIM2 CH2 (AF1)
timer A15 AF1
\# pin A15: TIM2 CH1 (AF1)
timer C08 AF3
\# pin C08: TIM8 CH3 (AF3)
timer C09 AF3
\# pin C09: TIM8 CH4 (AF3)
timer A08 AF1
\# pin A08: TIM1 CH1 (AF1)
timer B08 AF3
\# pin B08: TIM10 CH1 (AF3)
timer B10 AF1
\# pin B10: TIM2 CH3 (AF1)
timer A02 AF2
\# pin A02: TIM5 CH3 (AF2)
timer A03 AF2
\# pin A03: TIM5 CH4 (AF2)
\# dma
dma SPI\_TX 1 NONE
dma SPI\_TX 2 NONE
dma SPI\_TX 3 NONE
dma SPI\_TX 4 NONE
dma SPI\_RX 1 NONE
dma SPI\_RX 2 NONE
dma SPI\_RX 3 NONE
dma SPI\_RX 4 NONE
dma ADC 1 NONE
dma ADC 2 NONE
dma ADC 3 0
\# ADC 3: DMA2 Stream 0 Channel 2
dma UART\_TX 1 NONE
dma UART\_TX 2 NONE
dma UART\_TX 3 NONE
dma UART\_TX 4 NONE
dma UART\_TX 5 NONE
dma UART\_TX 6 NONE
dma UART\_TX 7 NONE
dma UART\_TX 8 NONE
dma UART\_RX 1 NONE
dma UART\_RX 2 NONE
dma UART\_RX 3 NONE
dma UART\_RX 4 NONE
dma UART\_RX 5 NONE
dma UART\_RX 6 NONE
dma UART\_RX 7 NONE
dma UART\_RX 8 NONE
dma pin C06 0
\# pin C06: DMA2 Stream 2 Channel 0
dma pin B01 0
\# pin B01: DMA1 Stream 2 Channel 5
dma pin B04 0
\# pin B04: DMA1 Stream 4 Channel 5
dma pin B03 0
\# pin B03: DMA1 Stream 6 Channel 3
dma pin A15 0
\# pin A15: DMA1 Stream 5 Channel 3
dma pin C08 1
\# pin C08: DMA2 Stream 4 Channel 7
dma pin C09 0
\# pin C09: DMA2 Stream 7 Channel 7
dma pin A08 0
\# pin A08: DMA2 Stream 6 Channel 0
dma pin B08 NONE
dma pin B10 0
\# pin B10: DMA1 Stream 1 Channel 3
dma pin A02 0
\# pin A02: DMA1 Stream 0 Channel 6
dma pin A03 1
\# pin A03: DMA1 Stream 3 Channel 6
\# mixer
mixer QUADX
\# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
\# servo mixer
smix reset
\# feature
feature -RX\_PPM
feature -INFLIGHT\_ACC\_CAL
feature -RX\_SERIAL
feature -MOTOR\_STOP
feature -SERVO\_TILT
feature -RANGEFINDER
feature -RX\_PARALLEL\_PWM
feature -RX\_MSP
feature -RSSI\_ADC
feature -LED\_STRIP
feature -OSD
feature -CHANNEL\_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -RX\_SPI
feature -ESC\_SENSOR
feature -ANTI\_GRAVITY
feature -DYNAMIC\_FILTER
feature RX\_SERIAL
feature MOTOR\_STOP
feature TELEMETRY
feature RSSI\_ADC
feature LED\_STRIP
feature OSD
feature AIRMODE
feature ANTI\_GRAVITY
feature DYNAMIC\_FILTER
\# beeper
beeper GYRO\_CALIBRATED
beeper RX\_LOST
beeper RX\_LOST\_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING\_GPS\_FIX
beeper ARMING\_GPS\_NO\_FIX
beeper BAT\_CRIT\_LOW
beeper BAT\_LOW
beeper GPS\_STATUS
beeper RX\_SET
beeper ACC\_CALIBRATION
beeper ACC\_CALIBRATION\_FAIL
beeper READY\_BEEP
beeper MULTI\_BEEPS
beeper DISARM\_REPEAT
beeper ARMED
beeper SYSTEM\_INIT
beeper ON\_USB
beeper BLACKBOX\_ERASE
beeper CRASH\_FLIP
beeper CAM\_CONNECTION\_OPEN
beeper CAM\_CONNECTION\_CLOSE
beeper RC\_SMOOTHING\_INIT\_FAIL
\# beacon
beacon -RX\_LOST
beacon RX\_SET
\# map
map AETR1234
\# serial
serial 4 1 115200 57600 0 115200
\# led
led 0 6,7::CB:1
led 1 7,7::CB:2
led 2 8,7::CB:1
led 3 9,7::CB:2
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
\# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
\# mode\_color
mode\_color 0 0 1
mode\_color 0 1 11
mode\_color 0 2 2
mode\_color 0 3 13
mode\_color 0 4 10
mode\_color 0 5 3
mode\_color 1 0 5
mode\_color 1 1 11
mode\_color 1 2 3
mode\_color 1 3 13
mode\_color 1 4 10
mode\_color 1 5 3
mode\_color 2 0 10
mode\_color 2 1 11
mode\_color 2 2 4
mode\_color 2 3 13
mode\_color 2 4 10
mode\_color 2 5 3
mode\_color 3 0 8
mode\_color 3 1 11
mode\_color 3 2 4
mode\_color 3 3 13
mode\_color 3 4 10
mode\_color 3 5 3
mode\_color 4 0 7
mode\_color 4 1 11
mode\_color 4 2 3
mode\_color 4 3 13
mode\_color 4 4 10
mode\_color 4 5 3
mode\_color 5 0 0
mode\_color 5 1 0
mode\_color 5 2 0
mode\_color 5 3 0
mode\_color 5 4 0
mode\_color 5 5 0
mode\_color 6 0 6
mode\_color 6 1 10
mode\_color 6 2 1
mode\_color 6 3 0
mode\_color 6 4 0
mode\_color 6 5 2
mode\_color 6 6 3
mode\_color 6 7 6
mode\_color 6 8 0
mode\_color 6 9 0
mode\_color 6 10 0
mode\_color 7 0 3
\# aux
aux 0 0 0 1700 2100 0 0
aux 1 1 2 1700 2100 0 0
aux 2 13 1 1700 2100 0 0
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
\# adjrange
\# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
\# vtxtable
vtxtable bands 0
vtxtable channels 0
vtxtable powerlevels 0
vtxtable powervalues
vtxtable powerlabels
\# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
\# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
\# master
set gyro\_hardware\_lpf = NORMAL
set gyro\_lowpass\_type = PT1
set gyro\_lowpass\_hz = 200
set gyro\_lowpass2\_type = PT1
set gyro\_lowpass2\_hz = 250
set gyro\_notch1\_hz = 0
set gyro\_notch1\_cutoff = 0
set gyro\_notch2\_hz = 0
set gyro\_notch2\_cutoff = 0
set gyro\_calib\_duration = 125
set gyro\_calib\_noise\_limit = 48
set gyro\_offset\_yaw = 0
set gyro\_overflow\_detect = ALL
set yaw\_spin\_recovery = AUTO
set yaw\_spin\_threshold = 1950
set gyro\_to\_use = FIRST
set dyn\_notch\_width\_percent = 8
set dyn\_notch\_q = 120
set dyn\_notch\_min\_hz = 150
set dyn\_notch\_max\_hz = 600
set dyn\_lpf\_gyro\_min\_hz = 200
set dyn\_lpf\_gyro\_max\_hz = 500
set gyro\_filter\_debug\_axis = ROLL
set acc\_hardware = AUTO
set acc\_lpf\_hz = 10
set acc\_trim\_pitch = 0
set acc\_trim\_roll = 0
set acc\_calibration = -114,-50,-43,1
set align\_mag = DEFAULT
set mag\_align\_roll = 0
set mag\_align\_pitch = 0
set mag\_align\_yaw = 0
set mag\_bustype = I2C
set mag\_i2c\_device = 1
set mag\_i2c\_address = 0
set mag\_spi\_device = 0
set mag\_hardware = NONE
set mag\_declination = 0
set mag\_calibration = 0,0,0
set baro\_bustype = I2C
set baro\_spi\_device = 0
set baro\_i2c\_device = 1
set baro\_i2c\_address = 0
set baro\_hardware = AUTO
set baro\_tab\_size = 21
set baro\_noise\_lpf = 600
set baro\_cf\_vel = 985
set mid\_rc = 1500
set min\_check = 1050
set max\_check = 1900
set rssi\_channel = 0
set rssi\_src\_frame\_errors = OFF
set rssi\_scale = 100
set rssi\_offset = 0
set rssi\_invert = OFF
set rssi\_src\_frame\_lpf\_period = 30
set rc\_interp = AUTO
set rc\_interp\_ch = RPYT
set rc\_interp\_int = 19
set rc\_smoothing\_type = FILTER
set rc\_smoothing\_input\_hz = 0
set rc\_smoothing\_derivative\_hz = 0
set rc\_smoothing\_debug\_axis = ROLL
set rc\_smoothing\_input\_type = BIQUAD
set rc\_smoothing\_derivative\_type = AUTO
set rc\_smoothing\_auto\_smoothness = 10
set fpv\_mix\_degrees = 0
set max\_aux\_channels = 14
set serialrx\_provider = CRSF
set serialrx\_inverted = OFF
set spektrum\_sat\_bind = 0
set spektrum\_sat\_bind\_autoreset = ON
set srxl2\_unit\_id = 1
set srxl2\_baud\_fast = ON
set sbus\_baud\_fast = OFF
set crsf\_use\_rx\_snr = OFF
set airmode\_start\_throttle\_percent = 25
set rx\_min\_usec = 885
set rx\_max\_usec = 2115
set serialrx\_halfduplex = OFF
set rx\_spi\_protocol = V202\_250K
set rx\_spi\_bus = 0
set rx\_spi\_led\_inversion = OFF
set adc\_device = 3
set adc\_vrefint\_calibration = 0
set adc\_tempsensor\_calibration30 = 0
set adc\_tempsensor\_calibration110 = 0
set input\_filtering\_mode = OFF
set blackbox\_p\_ratio = 32
set blackbox\_device = SPIFLASH
set blackbox\_record\_acc = ON
set blackbox\_mode = NORMAL
set min\_throttle = 1070
set max\_throttle = 2000
set min\_command = 1000
set dshot\_idle\_value = 550
set dshot\_burst = ON
set dshot\_bidir = OFF
set dshot\_bitbang = AUTO
set dshot\_bitbang\_timer = AUTO
set use\_unsynced\_pwm = OFF
set motor\_pwm\_protocol = DSHOT600
set motor\_pwm\_rate = 480
set motor\_pwm\_inversion = OFF
set motor\_poles = 14
set thr\_corr\_value = 0
set thr\_corr\_angle = 800
set failsafe\_delay = 4
set failsafe\_off\_delay = 10
set failsafe\_throttle = 1000
set failsafe\_switch\_mode = STAGE1
set failsafe\_throttle\_low\_delay = 100
set failsafe\_procedure = DROP
set failsafe\_recovery\_delay = 20
set failsafe\_stick\_threshold = 30
set align\_board\_roll = 0
set align\_board\_pitch = 0
set align\_board\_yaw = 180
set gimbal\_mode = NORMAL
set bat\_capacity = 0
set vbat\_max\_cell\_voltage = 430
set vbat\_full\_cell\_voltage = 410
set vbat\_min\_cell\_voltage = 330
set vbat\_warning\_cell\_voltage = 350
set vbat\_hysteresis = 1
set current\_meter = ADC
set battery\_meter = ADC
set vbat\_detect\_cell\_voltage = 300
set use\_vbat\_alerts = ON
set use\_cbat\_alerts = OFF
set cbat\_alert\_percent = 10
set vbat\_cutoff\_percent = 100
set force\_battery\_cell\_count = 0
set vbat\_display\_lpf\_period = 30
set vbat\_sag\_lpf\_period = 2
set ibat\_lpf\_period = 10
set vbat\_duration\_for\_warning = 0
set vbat\_duration\_for\_critical = 0
set vbat\_scale = 110
set vbat\_divider = 10
set vbat\_multiplier = 1
set ibata\_scale = 170
set ibata\_offset = 0
set ibatv\_scale = 0
set ibatv\_offset = 0
set beeper\_inversion = ON
set beeper\_od = OFF
set beeper\_frequency = 0
set beeper\_dshot\_beacon\_tone = 3
set yaw\_motors\_reversed = OFF
set crashflip\_motor\_percent = 0
set crashflip\_expo = 35
set 3d\_deadband\_low = 1406
set 3d\_deadband\_high = 1514
set 3d\_neutral = 1460
set 3d\_deadband\_throttle = 50
set 3d\_limit\_low = 1000
set 3d\_limit\_high = 2000
set 3d\_switched\_mode = OFF
set servo\_center\_pulse = 1500
set servo\_pwm\_rate = 50
set servo\_lowpass\_hz = 0
set tri\_unarmed\_servo = ON
set channel\_forwarding\_start = 4
set reboot\_character = 82
set serial\_update\_rate\_hz = 100
set imu\_dcm\_kp = 2500
set imu\_dcm\_ki = 0
set small\_angle = 25
set auto\_disarm\_delay = 5
set gyro\_cal\_on\_first\_arm = OFF
set gps\_provider = NMEA
set gps\_sbas\_mode = NONE
set gps\_sbas\_integrity = OFF
set gps\_auto\_config = ON
set gps\_auto\_baud = OFF
set gps\_ublox\_use\_galileo = OFF
set gps\_ublox\_mode = AIRBORNE
set gps\_set\_home\_point\_once = OFF
set gps\_use\_3d\_speed = OFF
set gps\_rescue\_angle = 32
set gps\_rescue\_initial\_alt = 50
set gps\_rescue\_descent\_dist = 200
set gps\_rescue\_landing\_alt = 5
set gps\_rescue\_landing\_dist = 10
set gps\_rescue\_ground\_speed = 2000
set gps\_rescue\_throttle\_p = 150
set gps\_rescue\_throttle\_i = 20
set gps\_rescue\_throttle\_d = 50
set gps\_rescue\_velocity\_p = 80
set gps\_rescue\_velocity\_i = 20
set gps\_rescue\_velocity\_d = 15
set gps\_rescue\_yaw\_p = 40
set gps\_rescue\_throttle\_min = 1100
set gps\_rescue\_throttle\_max = 1600
set gps\_rescue\_ascend\_rate = 500
set gps\_rescue\_descend\_rate = 150
set gps\_rescue\_throttle\_hover = 1280
set gps\_rescue\_sanity\_checks = RESCUE\_SANITY\_ON
set gps\_rescue\_min\_sats = 8
set gps\_rescue\_min\_dth = 100
set gps\_rescue\_allow\_arming\_without\_fix = OFF
set gps\_rescue\_alt\_mode = MAX\_ALT
set gps\_rescue\_use\_mag = ON
set deadband = 0
set yaw\_deadband = 0
set yaw\_control\_reversed = OFF
set pid\_process\_denom = 1
set runaway\_takeoff\_prevention = ON
set runaway\_takeoff\_deactivate\_delay = 500
set runaway\_takeoff\_deactivate\_throttle\_percent = 20
set thrust\_linear = 0
set transient\_throttle\_limit = 0
set tlm\_inverted = OFF
set tlm\_halfduplex = ON
set frsky\_default\_lat = 0
set frsky\_default\_long = 0
set frsky\_gps\_format = 0
set frsky\_unit = IMPERIAL
set frsky\_vfas\_precision = 0
set hott\_alarm\_int = 5
set pid\_in\_tlm = OFF
set report\_cell\_voltage = OFF
set ibus\_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0
set mavlink\_mah\_as\_heading\_divisor = 0
set telemetry\_disabled\_voltage = OFF
set telemetry\_disabled\_current = OFF
set telemetry\_disabled\_fuel = OFF
set telemetry\_disabled\_mode = OFF
set telemetry\_disabled\_acc\_x = OFF
set telemetry\_disabled\_acc\_y = OFF
set telemetry\_disabled\_acc\_z = OFF
set telemetry\_disabled\_pitch = OFF
set telemetry\_disabled\_roll = OFF
set telemetry\_disabled\_heading = OFF
set telemetry\_disabled\_altitude = OFF
set telemetry\_disabled\_vario = OFF
set telemetry\_disabled\_lat\_long = OFF
set telemetry\_disabled\_ground\_speed = OFF
set telemetry\_disabled\_distance = OFF
set telemetry\_disabled\_esc\_current = ON
set telemetry\_disabled\_esc\_voltage = ON
set telemetry\_disabled\_esc\_rpm = ON
set telemetry\_disabled\_esc\_temperature = ON
set telemetry\_disabled\_temperature = OFF
set ledstrip\_visual\_beeper = OFF
set ledstrip\_visual\_beeper\_color = WHITE
set ledstrip\_grb\_rgb = GRB
set ledstrip\_profile = STATUS
set ledstrip\_race\_color = ORANGE
set ledstrip\_beacon\_color = WHITE
set ledstrip\_beacon\_period\_ms = 500
set ledstrip\_beacon\_percent = 50
set ledstrip\_beacon\_armed\_only = OFF
set sdcard\_detect\_inverted = OFF
set sdcard\_mode = OFF
set sdcard\_dma = OFF
set sdcard\_spi\_bus = 0
set sdio\_clk\_bypass = OFF
set sdio\_use\_cache = OFF
set sdio\_use\_4bit\_width = OFF
set osd\_units = METRIC
set osd\_warn\_arming\_disable = ON
set osd\_warn\_batt\_not\_full = ON
set osd\_warn\_batt\_warning = ON
set osd\_warn\_batt\_critical = ON
set osd\_warn\_visual\_beeper = ON
set osd\_warn\_crash\_flip = ON
set osd\_warn\_esc\_fail = ON
set osd\_warn\_core\_temp = ON
set osd\_warn\_rc\_smoothing = ON
set osd\_warn\_fail\_safe = ON
set osd\_warn\_launch\_control = ON
set osd\_warn\_no\_gps\_rescue = ON
set osd\_warn\_gps\_rescue\_disabled = ON
set osd\_warn\_rssi = OFF
set osd\_warn\_link\_quality = OFF
set osd\_warn\_rssi\_dbm = OFF
set osd\_warn\_over\_cap = OFF
set osd\_rssi\_alarm = 20
set osd\_link\_quality\_alarm = 80
set osd\_rssi\_dbm\_alarm = -60
set osd\_cap\_alarm = 2200
set osd\_alt\_alarm = 100
set osd\_distance\_alarm = 0
set osd\_esc\_temp\_alarm = -128
set osd\_esc\_rpm\_alarm = -1
set osd\_esc\_current\_alarm = -1
set osd\_core\_temp\_alarm = 70
set osd\_ah\_max\_pit = 20
set osd\_ah\_max\_rol = 40
set osd\_ah\_invert = OFF
set osd\_logo\_on\_arming = OFF
set osd\_logo\_on\_arming\_duration = 5
set osd\_tim1 = 2560
set osd\_tim2 = 2561
set osd\_vbat\_pos = 14770
set osd\_rssi\_pos = 14776
set osd\_link\_quality\_pos = 234
set osd\_rssi\_dbm\_pos = 234
set osd\_tim\_1\_pos = 234
set osd\_tim\_2\_pos = 234
set osd\_remaining\_time\_estimate\_pos = 234
set osd\_flymode\_pos = 14722
set osd\_anti\_gravity\_pos = 234
set osd\_g\_force\_pos = 234
set osd\_throttle\_pos = 234
set osd\_vtx\_channel\_pos = 234
set osd\_crosshairs\_pos = 205
set osd\_ah\_sbar\_pos = 206
set osd\_ah\_pos = 78
set osd\_current\_pos = 14753
set osd\_mah\_drawn\_pos = 234
set osd\_motor\_diag\_pos = 234
set osd\_craft\_name\_pos = 14763
set osd\_display\_name\_pos = 234
set osd\_gps\_speed\_pos = 234
set osd\_gps\_lon\_pos = 234
set osd\_gps\_lat\_pos = 234
set osd\_gps\_sats\_pos = 234
set osd\_home\_dir\_pos = 234
set osd\_home\_dist\_pos = 234
set osd\_flight\_dist\_pos = 234
set osd\_compass\_bar\_pos = 234
set osd\_altitude\_pos = 234
set osd\_pid\_roll\_pos = 234
set osd\_pid\_pitch\_pos = 234
set osd\_pid\_yaw\_pos = 234
set osd\_debug\_pos = 234
set osd\_power\_pos = 234
set osd\_pidrate\_profile\_pos = 234
set osd\_warnings\_pos = 14665
set osd\_avg\_cell\_voltage\_pos = 234
set osd\_pit\_ang\_pos = 234
set osd\_rol\_ang\_pos = 234
set osd\_battery\_usage\_pos = 234
set osd\_disarmed\_pos = 234
set osd\_nheading\_pos = 234
set osd\_nvario\_pos = 234
set osd\_esc\_tmp\_pos = 234
set osd\_esc\_rpm\_pos = 234
set osd\_esc\_rpm\_freq\_pos = 234
set osd\_rtc\_date\_time\_pos = 234
set osd\_adjustment\_range\_pos = 234
set osd\_flip\_arrow\_pos = 234
set osd\_core\_temp\_pos = 234
set osd\_log\_status\_pos = 234
set osd\_stick\_overlay\_left\_pos = 234
set osd\_stick\_overlay\_right\_pos = 234
set osd\_stick\_overlay\_radio\_mode = 2
set osd\_rate\_profile\_name\_pos = 234
set osd\_pid\_profile\_name\_pos = 234
set osd\_profile\_name\_pos = 234
set osd\_rcchannels\_pos = 234
set osd\_camera\_frame\_pos = 35
set osd\_efficiency\_pos = 234
set osd\_stat\_rtc\_date\_time = OFF
set osd\_stat\_tim\_1 = OFF
set osd\_stat\_tim\_2 = ON
set osd\_stat\_max\_spd = ON
set osd\_stat\_max\_dist = OFF
set osd\_stat\_min\_batt = ON
set osd\_stat\_endbatt = OFF
set osd\_stat\_battery = OFF
set osd\_stat\_min\_rssi = ON
set osd\_stat\_max\_curr = ON
set osd\_stat\_used\_mah = ON
set osd\_stat\_max\_alt = OFF
set osd\_stat\_bbox = ON
set osd\_stat\_bb\_no = ON
set osd\_stat\_max\_g\_force = OFF
set osd\_stat\_max\_esc\_temp = OFF
set osd\_stat\_max\_esc\_rpm = OFF
set osd\_stat\_min\_link\_quality = OFF
set osd\_stat\_flight\_dist = OFF
set osd\_stat\_max\_fft = OFF
set osd\_stat\_total\_flights = OFF
set osd\_stat\_total\_time = OFF
set osd\_stat\_total\_dist = OFF
set osd\_stat\_min\_rssi\_dbm = OFF
set osd\_profile = 1
set osd\_profile\_1\_name = -
set osd\_profile\_2\_name = -
set osd\_profile\_3\_name = -
set osd\_gps\_sats\_show\_hdop = OFF
set osd\_displayport\_device = AUTO
set osd\_rcchannels = -1,-1,-1,-1
set osd\_camera\_frame\_width = 24
set osd\_camera\_frame\_height = 11
set task\_statistics = ON
set debug\_mode = NONE
set rate\_6pos\_switch = OFF
set cpu\_overclock = OFF
set pwr\_on\_arm\_grace = 5
set scheduler\_optimize\_rate = AUTO
set enable\_stick\_arming = OFF
set vtx\_band = 0
set vtx\_channel = 0
set vtx\_power = 0
set vtx\_low\_power\_disarm = OFF
set vtx\_freq = 0
set vtx\_pit\_mode\_freq = 0
set vtx\_halfduplex = ON
set vtx\_spi\_bus = 0
set vcd\_video\_system = AUTO
set vcd\_h\_offset = 0
set vcd\_v\_offset = 0
set max7456\_clock = DEFAULT
set max7456\_spi\_bus = 2
set max7456\_preinit\_opu = OFF
set displayport\_msp\_col\_adjust = 0
set displayport\_msp\_row\_adjust = 0
set displayport\_msp\_serial = 0
set displayport\_msp\_attrs = 0,0,0,0
set displayport\_msp\_use\_device\_blink = OFF
set displayport\_max7456\_col\_adjust = 0
set displayport\_max7456\_row\_adjust = 0
set displayport\_max7456\_inv = OFF
set displayport\_max7456\_blk = 0
set displayport\_max7456\_wht = 2
set esc\_sensor\_halfduplex = OFF
set esc\_sensor\_current\_offset = 0
set frsky\_spi\_autobind = OFF
set frsky\_spi\_tx\_id = 0,0
set frsky\_spi\_offset = 0
set frsky\_spi\_bind\_hop\_data = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
set frsky\_x\_rx\_num = 0
set frsky\_spi\_a1\_source = VBAT
set cc2500\_spi\_chip\_detect = ON
set led\_inversion = 0
set dashboard\_i2c\_bus = 1
set dashboard\_i2c\_addr = 60
set camera\_control\_mode = HARDWARE\_PWM
set camera\_control\_ref\_voltage = 330
set camera\_control\_key\_delay = 180
set camera\_control\_internal\_resistance = 470
set camera\_control\_button\_resistance = 450,270,150,68,0
set camera\_control\_inverted = OFF
set rangefinder\_hardware = NONE
set pinio\_config = 1,1,1,1
set pinio\_box = 40,41,255,255
set usb\_hid\_cdc = OFF
set usb\_msc\_pin\_pullup = ON
set flash\_spi\_bus = 3
set rcdevice\_init\_dev\_attempts = 6
set rcdevice\_init\_dev\_attempt\_interval = 1000
set rcdevice\_protocol\_version = 0
set rcdevice\_feature = 0
set gyro\_1\_bustype = SPI
set gyro\_1\_spibus = 1
set gyro\_1\_i2cBus = 0
set gyro\_1\_i2c\_address = 0
set gyro\_1\_sensor\_align = CW0
set gyro\_1\_align\_roll = 0
set gyro\_1\_align\_pitch = 0
set gyro\_1\_align\_yaw = 0
set gyro\_2\_bustype = SPI
set gyro\_2\_spibus = 1
set gyro\_2\_i2cBus = 0
set gyro\_2\_i2c\_address = 0
set gyro\_2\_sensor\_align = CW270
set gyro\_2\_align\_roll = 0
set gyro\_2\_align\_pitch = 0
set gyro\_2\_align\_yaw = 2700
set i2c1\_pullup = OFF
set i2c1\_overclock = ON
set i2c2\_pullup = OFF
set i2c2\_overclock = ON
set i2c3\_pullup = OFF
set i2c3\_overclock = ON
set mco2\_on\_pc9 = OFF
set timezone\_offset\_minutes = 0
set gyro\_rpm\_notch\_harmonics = 3
set gyro\_rpm\_notch\_q = 500
set gyro\_rpm\_notch\_min = 100
set dterm\_rpm\_notch\_harmonics = 0
set dterm\_rpm\_notch\_q = 500
set dterm\_rpm\_notch\_min = 100
set rpm\_notch\_lpf = 150
set flysky\_spi\_tx\_id = 0
set flysky\_spi\_rf\_channels = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
set stats = OFF
set stats\_total\_flights = 0
set stats\_total\_time\_s = 0
set stats\_total\_dist\_m = 0
set name = test
set display\_name = -
set position\_alt\_source = DEFAULT
set box\_user\_1\_name = -
set box\_user\_2\_name = -
set box\_user\_3\_name = -
set box\_user\_4\_name = -
\# profile 0
set profile\_name = -
set dyn\_lpf\_dterm\_min\_hz = 70
set dyn\_lpf\_dterm\_max\_hz = 170
set dyn\_lpf\_dterm\_curve\_expo = 5
set dterm\_lowpass\_type = PT1
set dterm\_lowpass\_hz = 150
set dterm\_lowpass2\_type = PT1
set dterm\_lowpass2\_hz = 150
set dterm\_notch\_hz = 0
set dterm\_notch\_cutoff = 0
set vbat\_pid\_gain = OFF
set vbat\_sag\_compensation = 0
set pid\_at\_min\_throttle = ON
set anti\_gravity\_mode = SMOOTH
set anti\_gravity\_threshold = 250
set anti\_gravity\_gain = 3500
set feedforward\_transition = 0
set acc\_limit\_yaw = 0
set acc\_limit = 0
set crash\_dthreshold = 50
set crash\_gthreshold = 400
set crash\_setpoint\_threshold = 350
set crash\_time = 500
set crash\_delay = 0
set crash\_recovery\_angle = 10
set crash\_recovery\_rate = 100
set crash\_limit\_yaw = 200
set crash\_recovery = OFF
set iterm\_rotation = OFF
set iterm\_relax = RP
set iterm\_relax\_type = SETPOINT
set iterm\_relax\_cutoff = 15
set iterm\_windup = 100
set iterm\_limit = 400
set pidsum\_limit = 500
set pidsum\_limit\_yaw = 400
set yaw\_lowpass\_hz = 0
set throttle\_boost = 5
set throttle\_boost\_cutoff = 15
set acro\_trainer\_angle\_limit = 20
set acro\_trainer\_lookahead\_ms = 50
set acro\_trainer\_debug\_axis = ROLL
set acro\_trainer\_gain = 75
set p\_pitch = 46
set i\_pitch = 90
set d\_pitch = 38
set f\_pitch = 95
set p\_roll = 42
set i\_roll = 85
set d\_roll = 35
set f\_roll = 90
set p\_yaw = 45
set i\_yaw = 90
set d\_yaw = 0
set f\_yaw = 90
set angle\_level\_strength = 50
set horizon\_level\_strength = 50
set horizon\_transition = 75
set level\_limit = 55
set horizon\_tilt\_effect = 75
set horizon\_tilt\_expert\_mode = OFF
set abs\_control\_gain = 0
set abs\_control\_limit = 90
set abs\_control\_error\_limit = 20
set abs\_control\_cutoff = 11
set use\_integrated\_yaw = OFF
set integrated\_yaw\_relax = 200
set d\_min\_roll = 23
set d\_min\_pitch = 25
set d\_min\_yaw = 0
set d\_min\_boost\_gain = 37
set d\_min\_advance = 20
set motor\_output\_limit = 100
set auto\_profile\_cell\_count = 0
set launch\_control\_mode = NORMAL
set launch\_trigger\_allow\_reset = ON
set launch\_trigger\_throttle\_percent = 20
set launch\_angle\_limit = 0
set launch\_control\_gain = 40
set ff\_interpolate\_sp = AVERAGED\_2
set ff\_spike\_limit = 60
set ff\_max\_rate\_limit = 100
set ff\_smooth\_factor = 37
set ff\_boost = 15
set idle\_min\_rpm = 0
set idle\_adjustment\_speed = 50
set idle\_p = 50
set idle\_pid\_limit = 200
set idle\_max\_increase = 150
set level\_race\_mode = OFF
\# rateprofile 0
set rateprofile\_name = -
set thr\_mid = 50
set thr\_expo = 0
set rates\_type = BETAFLIGHT
set roll\_rc\_rate = 100
set pitch\_rc\_rate = 100
set yaw\_rc\_rate = 100
set roll\_expo = 0
set pitch\_expo = 0
set yaw\_expo = 0
set roll\_srate = 70
set pitch\_srate = 70
set yaw\_srate = 70
set tpa\_rate = 65
set tpa\_breakpoint = 1350
set tpa\_mode = D
set throttle\_limit\_type = OFF
set throttle\_limit\_percent = 100
set roll\_rate\_limit = 1998
set pitch\_rate\_limit = 1998
set yaw\_rate\_limit = 1998
\# end the command batch
batch end
Hello,
\# dump
\# version
batch start
\# name: test
\# resources
resource PPM 1 C06
resource PWM 1 B10
resource PWM 2 A02
resource PWM 3 A03
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED 1 C15
resource LED 2 NONE
resource LED 3 NONE
\# timer
timer C06 AF3
timer B01 AF2
timer B04 AF2
timer B03 AF1
timer A15 AF1
timer C08 AF3
timer C09 AF3
timer A08 AF1
timer B08 AF3
timer B10 AF1
timer A02 AF2
timer A03 AF2
\# dma
dma SPI\_TX 1 NONE
dma SPI\_TX 2 NONE
dma SPI\_TX 3 NONE
dma SPI\_TX 4 NONE
dma SPI\_RX 1 NONE
dma SPI\_RX 2 NONE
dma SPI\_RX 3 NONE
dma SPI\_RX 4 NONE
dma ADC 1 NONE
dma ADC 2 NONE
dma ADC 3 0
dma UART\_TX 1 NONE
dma UART\_TX 2 NONE
dma UART\_TX 3 NONE
dma UART\_TX 4 NONE
dma UART\_TX 5 NONE
dma UART\_TX 6 NONE
dma UART\_TX 7 NONE
dma UART\_TX 8 NONE
dma UART\_RX 1 NONE
dma UART\_RX 2 NONE
dma UART\_RX 3 NONE
dma UART\_RX 4 NONE
dma UART\_RX 5 NONE
dma UART\_RX 6 NONE
dma UART\_RX 7 NONE
dma UART\_RX 8 NONE
dma pin C06 0
dma pin B01 0
dma pin B04 0
dma pin B03 0
dma pin A15 0
dma pin C08 1
dma pin C09 0
dma pin A08 0
dma pin B08 NONE
dma pin B10 0
dma pin A02 0
dma pin A03 1
\# mixer
mixer QUADX
\# servo
\# servo mixer
smix reset
\# feature
feature -RX\_PPM
feature -RX\_SERIAL
feature -RX\_MSP
feature -RSSI\_ADC
feature -LED\_STRIP
feature -OSD
feature -AIRMODE
feature -RX\_SPI
feature RX\_SERIAL
feature MOTOR\_STOP
feature TELEMETRY
feature RSSI\_ADC
feature LED\_STRIP
feature OSD
feature AIRMODE
\# beeper
beeper RX\_LOST
beeper DISARMING
beeper ARMING
beeper BAT\_LOW
beeper GPS\_STATUS
beeper RX\_SET
beeper READY\_BEEP
beeper MULTI\_BEEPS
beeper ARMED
beeper SYSTEM\_INIT
beeper ON\_USB
beeper CRASH\_FLIP
\# beacon
beacon -RX\_LOST
beacon RX\_SET
\# map
map AETR1234
\# serial
\# led
led 0 6,7::CB:1
led 1 7,7::CB:2
led 2 8,7::CB:1
led 3 9,7::CB:2
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
\# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
\# mode\_color
mode\_color 0 0 1
mode\_color 0 1 11
mode\_color 0 2 2
mode\_color 0 3 13
mode\_color 0 4 10
mode\_color 0 5 3
mode\_color 1 0 5
mode\_color 1 1 11
mode\_color 1 2 3
mode\_color 1 3 13
mode\_color 1 4 10
mode\_color 1 5 3
mode\_color 2 0 10
mode\_color 2 1 11
mode\_color 2 2 4
mode\_color 2 3 13
mode\_color 2 4 10
mode\_color 2 5 3
mode\_color 3 0 8
mode\_color 3 1 11
mode\_color 3 2 4
mode\_color 3 3 13
mode\_color 3 4 10
mode\_color 3 5 3
mode\_color 4 0 7
mode\_color 4 1 11
mode\_color 4 2 3
mode\_color 4 3 13
mode\_color 4 4 10
mode\_color 4 5 3
mode\_color 5 0 0
mode\_color 5 1 0
mode\_color 5 2 0
mode\_color 5 3 0
mode\_color 5 4 0
mode\_color 5 5 0
mode\_color 6 0 6
mode\_color 6 1 10
mode\_color 6 2 1
mode\_color 6 3 0
mode\_color 6 4 0
mode\_color 6 5 2
mode\_color 6 6 3
mode\_color 6 7 6
mode\_color 6 8 0
mode\_color 6 9 0
mode\_color 6 10 0
mode\_color 7 0 3
\# aux
\# adjrange
\# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
\# vtxtable
vtxtable bands 0
vtxtable channels 0
\# vtx
\# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
\# master
set mid\_rc = 1500
set adc\_device = 3
set deadband = 0
set vtx\_band = 0
set vtx\_power = 0
set vtx\_freq = 0
set stats = OFF
set name = test
\# profile 0
set acc\_limit = 0
set p\_pitch = 46
set i\_pitch = 90
set d\_pitch = 38
set f\_pitch = 95
set p\_roll = 42
set i\_roll = 85
set d\_roll = 35
set f\_roll = 90
set p\_yaw = 45
set i\_yaw = 90
set d\_yaw = 0
set f\_yaw = 90
set d\_min\_yaw = 0
set ff\_boost = 15
set idle\_p = 50
\# rateprofile 0
set thr\_mid = 50
set thr\_expo = 0
set roll\_expo = 0
set pitch\_expo = 0
set yaw\_expo = 0
set yaw\_srate = 70
set tpa\_rate = 65
set tpa\_mode = D
batch end
