23-May-2024, 02:08 AM (This post was last modified: 23-May-2024, 02:12 AM by SeismicCWave.)
Ok I am still a beginner and I have an annoying issue. So I guess this is as good a forum to post the question.
It is happening on two of my quads.
1) A Flywoo Fly Lens 85 with Walksnail. Flying with GNB 850 2S HV pack.
2) A scratch build 75mm with a Meteor 75 Air frame. Sub250 RedFox A1 AIO flight controller (The actual target for this flight controller is really a GEPRCF411SX1280). I am using some 0802 21500kV motors from Tiny Whoops. Flying with 1S BetaFPV 550 Lava HV pack.
On both quad batteries are full charge. The total battery voltage on the Fly Lens showed something like 8.5V. However the average single cell voltage showed 2.5V and I get a low battery land NOW warning. I had ti unplug a few times and eventually it will go away. I can also fly with the warning and the quad flew fine. I asked Flywoo and they said it is software. So I reloaded firmware and saved OSD page a few times and it finally went away or so I hoped.
Then on this 75 mm build using only 1 cell I am again getting this dumb low battery land now warning when I plug in the battery and put on the goggles. I unplug and re-plug and it went away.
So my question is can I get rid of the warning? Is there some place I had forgotten to click? A voltage that I have set wrong? Or is it a bug in BetaFlight 4.4.X?
Thanks in advance for your help.
Ok I like to post pictures. This one is called Snow White 75. I am using a CaddX Ant Lite 16:9 format camera. The camera is pretty nice. It is a pain to change the display on my goggles every time I fly this quad but the picture quality makes it worth while to change.
![[Image: qNzkoCTl.jpeg]](https://i.imgur.com/qNzkoCTl.jpeg)
