Osd not saving all elements
Hello. I have some osd issues..
After configuring and saving all the required elements and disconnected from configurator when i power up with lipo half of the elements are correctly saved in the desired position.
All the elements in the upper half of the screen are saved ok but the elements in the lower half are presents but in wrong position,they are all overlapped.
I also tried to save with lipo plugged but without result.
Fc matek f722se and bf 4.4.0
Thanks
Help please....
Try placing one item only each side up the screen where they do "plant", then move them down a line at a time checking each time till you find the lower limit, then add another two up and repeat.
[-] The following 1 user Likes Bad Raven's post:
  • lorentz
(01-Apr-2023, 06:06 PM)Bad Raven Wrote: Try placing one item only each side up the screen where they do "plant", then move them down a line at a time checking each time till you find the lower limit, then add another two up and repeat.
Thxx. Good idea!
If you can't get it working with Bad Raven's suggestion then please answer the following additional questions:
  1. Are you using an analog video system of a digital one?
  2. If it is digital system, which one exactly (which goggles and which VTX)?
  3. If you are using the original DJI FPV System, are your goggles rooted with WTFOS and msp-osd package installed?
  4. What version of Betaflight are you using?
(02-Apr-2023, 12:11 PM)SnowLeopardFPV Wrote: If you can't get it working with Bad Raven's suggestion then please answer the following additional questions:
Hello,sadly it does not work.All the elements in the lower third of the canvas are still overlapped.
The video system is analogue and before flashing bf 4.4.0 worked fine...
  Help OSD Working but Grey Screen Caelus_fpv 4 221 25-Apr-2024, 03:14 PM
Last Post: Caelus_fpv
  Betaflight OSD not showing any information, but OSD menu is working gwennoyel 22 10,586 19-Apr-2024, 08:35 PM
Last Post: Maxym666
  Help OSD Not Displaying Victory FPV 11 677 20-Mar-2024, 11:43 AM
Last Post: Victory FPV
  Black video but with OSD Dexter 6 295 08-Mar-2024, 10:42 AM
Last Post: Dexter
  Black screen and no OSD: Eachine TX06 + EV800 + DarwinFPV F411 Ultralight/Whoop AIO aprudnikoff 1 220 05-Mar-2024, 09:18 PM
