OpenTX 2.2.4 Release
I just noticed that OpenTX 2.2.4 was released 6 days ago.
You will need a newer version of the Open TX Companion (v2.2.4) and also newer SD Card content (2.2V0021) for this new release. Everything you need is on the web page at the link below...
https://www.open-tx.org/2019/07/11/opentx-2.2.4
A summary of the changes and bug fixes applied to this new 2.2.4 version since 2.2.3 was last released are as follows:-
  • Multiprotocol: updated to match 1.2.1.63 (thx MRC3742)
  • Taranis: fix an issue where changing max baud could turn external module on
  • Taranis: remove Alt from top bar display in FAI mode
  • Horus: fix plane and glider wizard when no motor is selected
  • FrSky: fix ModelID unduly checked in D8 mode
  • FrSky: support Neuron ESC telemetry
  • Sky9X : add Flex R9M support
  • Crossfire: add vario sensor
  • Crossfire: raw CRSF telemetry data can be mirrored on AUX serial port
  • LUA: fix an issue where sportTelemetryPush() was not working when crc is 0x7D or 0x7E
  • LUA: add telem1 to telem32v
  • LUA: add lua mixers outputs
  • Companion: fix negative gvar precision (thx elecpower)
  • Companion: add mouseover tool tips to label fields with context menus (thx elecpower)
  • Companion: fix special function Inc/Dec Gvar (thx elecpower)
  • Companion: better multiprotocol name handling (thx MRC3742)
  • Companion: GPS format matches radio choice (thx elecpower)
To flash the new version, see Oscar's tutorial at the link below on how to do that...
https://oscarliang.com/flash-opentx-firmware-taranis
[-] The following 3 users Like SnowLeopardFPV's post:
  • hugnosed_bat, roberthein, brnmd
Nice, I'll give it a go this weekend!
Not that it will make any difference, I just like to keep all things up to date.
(17-Jul-2019, 05:06 PM)brnmd Wrote: Nice, I'll give it a go this weekend!
Yep, me too. There is nothing in the release notes that are going to affect me but I've always had OCD about being on latest versions of any software/firmware Big Grin
I'll install 2.2.4 on my X9D+ tonight and then check that everything still works OK sometime over the next few days.
Installed on the last weekend just because I was on 2.2.0 and wanted to update everything to EU LBT protocol. Couldn't update my xsr's so stayed for now on fct but upgraded the tx anyway. For all of you on stock splash screen update that too if you have the time to make the graphics. I liked it quite a lot Smile
Well I was just going to do the update on my X9D+ but the OpenTX download server appears to be down for whatever reason. When I select the firmware options I want and click on the "Download firmware" button in OpenTX Companion 2.2.4 I just get the following message...
[Image: KT3tG3O.jpg]
Trying to access the same URL in a web browser just gives me the HTTP "404 Not Found" page so something must be up with the nginx web server config. I guess I'll have to wait until tomorrow and try again in the hope that someone has fixed the issue by then.
https://downloads.open-tx.org/2.2/rc/firmware/getfw.php
Already updated it and downloaded a new version of Lua Scripts and of course the beautiful Amber Sound pack again Smile
Wierd. I'm still getting the 404 error when I try and download the firmware.
If you click the link in my previous post, what page comes up?
And what firmware options are you selecting when doing a download?
I get the 404 error.
I don't ha e OpenTX, just testing the link for you.
I had no trouble downloading all files through OpenTX Companion. I did get the 404 from your link.
All current here.
Thanks for the heads up.
Scott
I will wait until some of my guinea pig friends here use this update for awhile before I step off.  I still don't trust BF 4.0+ and I don't want a replay of that mess with open TX.....I wonder how long BF 3.5.7 will be available? Thinking Big Grin
OK, I don't know what was up with my install of OpenTX Companion but any version I installed was giving me the same 404 error when trying to download firmware. I completely uninstalled it including deletion of any user settings, manually deleted any left over files in "C:\Program Files (x86)\OpenTX\Companion 2.2", and deleted the "HKEY_CURRENT_USER\Software\OpenTX\Companion 2.2" registry hive. I then re-installed OpenTX Companion 2.2.4 and I was able to download firmware files without any further issues. So if anyone else get the same issue then try doing the same.
My X9D+ is now on OpenTX 2.2.4 so I'll do a hover test tomorrow in the back garden and then test it out properly if the weather holds up and I get a chance to go flying later in the day.
Huh Hello
I'm new on this forum, and I find that Snowleopard has problem with his companion version.
I get the same error by asking for downloading open TX 2.2.4 , download failed !
I try to do like you by deleting openTX files, but were is the "HKEY_CURRENT_USER\Software\OpenTX\Companion 2.2" registry hive ? I cannot find it ?
(30-Jul-2019, 09:10 AM)Francois Wrote: I try to do like you by deleting openTX files, but were is the "HKEY_CURRENT_USER\Software\OpenTX\Companion 2.2" registry hive ? I cannot find it ?
If you don't have that registry hive then it means you've either never had a version of Companion 2.2.x installed on your machine or the uninstall of it succeeded cleanly. Uninstalling Companion 2.2.x should delete that hive automatically but it doesn't always seem to be the case. If yours is already gone then you are all good.
Were you able to download and install Companion 2.2.4 ?
Downloaded the firmware though the companion!
Didn't had it installed on the laptop I did it though so it was a fresh install too, maybe that's the trick.
(17-Jul-2019, 11:09 PM)SnowLeopardFPV Wrote: Well I was just going to do the update on my X9D+ but the OpenTX download server appears to be down for whatever reason. When I select the firmware options I want and click on the "Download firmware" button in OpenTX Companion 2.2.4 I just get the following message...
Solved such problem with choosing to use only Stable releases
  Announcement ExpressLRS 3.4.0 *** FINAL RELEASE *** Now Available SnowLeopardFPV 1 567 19-May-2024, 12:44 AM
  Announcement EdgeTX "Centurion" v2.10.0 *** FINAL RELEASE *** Now Available SnowLeopardFPV 0 513 12-May-2024, 11:35 PM
  Announcement EdgeTX "Centurion" v2.10.0 Release Candidate 4 Now Available SnowLeopardFPV 0 263 08-May-2024, 03:07 PM
  Announcement ExpressLRS 3.4.0 Release Candidate 3 Now Available SnowLeopardFPV 2 933 28-Apr-2024, 01:30 AM
  Can I easily go from OpenTX 2. Version to older versions? baevans11 5 294 20-Apr-2024, 11:21 AM
