Old camera wires help |
23-Mar-2021, 10:16 PM I don’t have this particular camera but the usual standard on all my cameras has been: Red= 5v or Vbat Black= Ground Yellow= Video White= Could be OSD camera control/settings if the camera supports it 23-Mar-2021, 10:41 PM Thanks So if I go for Red= 5v or Vbat Black= Ground Yellow= Video As the flight controler has built in OSD it should work. Thanks again 23-Mar-2021, 10:47 PM The white wire could also be an audio connection if the camera has a built in microphone. 23-Mar-2021, 10:48 PM (This post was last modified: 23-Mar-2021, 10:49 PM by hugnosed_bat.) red and black should be + and - the two others doesnt make sense to me, i cant see a mic, why should there be a two signal cable. there isnt osd on such a cam you could wire plus and minus and check if you get video rom the yellow or white cable. my suggestion would be be a modern nano cam. as example a runcam nano. i believe you will have bad experience/image quality on yours, 10-20 bucks for a modern cam, better image could make a huge difference in flightexperience. 24-Mar-2021, 12:34 AM aaah, good found, a mic :-) it looks like pretty small cam, nano sized cams should be close about the size. if you dont need to save weight or need small size, you could get a micro sized cam. what kind of build is it? 24-Mar-2021, 08:43 AM (24-Mar-2021, 12:34 AM)[aaah, good found, a mic :-) Wrote: it looks like pretty small cam, nano sized cams should be close about the size. It's an 3" one made up of stuff lying around mostley. organic 24-Mar-2021, 10:50 AM "mostley. organic" ;-) nice ;-) looks good, seems a nano cam is required. https://shop.runcam.com/nano-size-camera/ https://www.foxeer.com/foxeer-nano-tooth...able-g-284 https://www.foxeer.com/foxeer-razer-nano...mera-g-273 the runcam nano racer 2 or the foxeer predator nano would be the best, but cost are high too. |
Camera Plug Wiring | segler999 | 5 | 539 | 30-Dec-2023, 05:17 PM Last Post: segler999 | |
Camera and VTX connection best practice? | husafreak | 9 | 918 | 24-Dec-2023, 10:11 PM Last Post: husafreak | |
Best hd camera for 5 inch freestyle drone? | PJKMBAKER | 3 | 742 | 30-Sep-2023, 12:05 PM Last Post: SnowLeopardFPV | |
Analog Camera Settings help for night / low light | MajorKook | 5 | 1,133 | 03-May-2023, 04:57 AM Last Post: cali_quad | |
Help analog camera OSD pin | nicetomeetyou | 10 | 1,421 | 15-Apr-2023, 09:22 AM Last Post: SnowLeopardFPV |
