30-Dec-2023, 02:02 AM
I like the idea of analog camera wire plugs that allow quick change-out of cameras. Some FC AIOs have receptacles for such plugs. I think most, if not all of them, are JST 0.8.
The problem is the tower of Babel for the wiring.
The Runcam Nano 3 and Tiny Whoop Pinch cams have left-to-right yellow-red-black as viewed on the pin retainer side. FC AIO boards with compatible receptacles are the Happy Model X12, F4, DiamondF4, and probably some others.
The BetaFPV CO3 has yellow-black-red from the same viewpoint. It plugs into the MO3 vtx board, and probably some others.
If I want to use the CO3 camera with a F4 AIO, I have to either solder a new pigtail or pull and re-insert the pins (good luck doing this with JST 0.8--those puppies are TINY).
Why? Why not standardize this? Oh, OK, I suppose vendors want to lock customers into their system. I get that, but come on!!
No, I don't want to have to solder camera wires directly to the board. That's the whole point of plugs and receptacles.
Has somebody made a big listing of which cameras plug into which AIO boards and vtx boards without modifications?
