19-Jun-2020, 01:44 PM
This new version of the F.PORT protocol is only supported on ACCESS capable receivers. Details are on FrSky's main website at the following link and I have copied/pastes the same information below.
https://www.frsky-rc.com/f-port-2-0
FrSky Wrote:Introduction
The F.Port 2.0 protocol is the upgraded protocol from 1.0 version which integrates SBUS and S.Port into one line. This new protocol enables one Host device to communicate on one line with several Slave accessories. All connected devices by ACCESS receiver (Host) can be configured wirelessly to the ACCESS radio base on this protocol.
Integration Of SBUS & S.PORT
To complete the duplex data transmission between devices, the Signal via SBUS works separately unlike the configuration command & telemetry data interaction via Smart Port base on two different protocols.
F.Port now allows you to connect only one standard servo cable with the integration of SBUS signals and S.Port telemetry through a single connection. This opens up the possibility of seamlessly pairing a single receiver on F.Port protocol with multiple telemetry devices as well as simplifying one’s setup.
Wireless Configuration & Firmware Upgrade
Usage without Flight Controller
Bound to an ACCESS protocol radio, the Archer receivers can be updated over the air and configured by a specific LUA script without a cable connection. With the addition of F.Port 2.0 protocol, this system supports multiple devices like sensors, servos, video transmitter, ESC, and other accessories to be daisy-chained together to be controlled by the receiver (Host) via F.Port.
Usage includes Flight Controller
Standard models equipped with Flight Controllers usually use the Flight Controller as a hub to connect components like motors, video transmitter, ESC, and other accessories. With the new F.Port 2.0 protocol, the flight controller can host its’ own line of accessory (Slave), in addition, the flight controller (Slave) can also be controlled by the (Host) receiver.
Usage with FreeLink App
The ACCESS radio that comes equipped with a PARA module, pairing the F.Port 2.0 protocol can enable the FreeLink App to configure and flash the firmware for any F.Port 2.0 capable devices amongst the product line.
FAQ
Q: What ACCESS receivers will be F.Port 2.0 capable?
Host receiver must be an F.Port 2.0 capable ACCESS receiver. The Archer series and upcoming other new series receivers (TD, etc.) will apply this protocol.
Q: What changes from 1.0 to 2.0 version?
The 1.0 version initially realized and simplified the F.Port bus transmission with integrated SBUS and S.Port from one Receiver to another device. The upgraded 2.0 can enable more devices to form into a chain to connect by the unique host device, all the connected devices can be upgraded and configured on the ACCESS radio over the air.
