Threads: 38
Likes Given: 430
118 10-Jul-2021, 08:11 AM (This post was last modified: 10-Jul-2021, 08:11 AM by kafie1980.) So you are seeing transmitter stick movements when connected to Betaflight? I assume you have enabled the Serial receiver provider to CRSF (Configuration tab) and also selected the correct channel map (Receiver tab)?
Any warning on the OSD when you try to arm?
Do you get a GPS lock? Dis you try enabling "Allow arming without fix" in the Failsafe tab if you have selected GPS rescue mode?
What Barometer do you have?
Threads: 172
Likes Received: 2,297 in 1,844 posts
Likes Given: 4,751
103
you need to try them with props on, outside in save condition
Threads: 0
Likes Received: 0 in 0 posts
Likes Given: 0
27-Jul-2021, 10:07 AM (This post was last modified: 06-Dec-2021, 11:57 PM by SnowLeopardFPV. Edit Reason: [Moderator Edit] Removed spam links. ) [Moderator Edit] This is a clone of an old thread on reddit HERE. This user account is for a known spammer who included spam links in the post, so those have been removed and the user account has been banned. The thread will remain [undeleted] because other members have already added contributions that might still be useful to others. What version of Betaflight is on your quad? Needs 4.1 or higher for the VTX features I believe...
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 28-Jul-2021, 06:04 AM (This post was last modified: 28-Jul-2021, 06:06 AM by Kevin2112.) You cannot arm the quad when hooked up to BF, so the radio won’t control anything. With your props off connect just the battery no USB cable. You should be able to arm the quad and motors should spin at the idle speed. Give some small stick movements and very little throttle as you have no load on the motors. Don’t be alarmed if the motors start acting up this is normal without props on, just disarm and they will stop.
