Need help swwaping pin on Matek f405
Hi, can anyone tell me if its possible to change the S4 pin to S5 on a MatekSYS f405-STD FC?
What do you mean by "change the pin"? What is it exactly that you're trying to do?
im connecting my flight cntroller to an ESC but the pin for motor 4 has been damaged so I want to use either s5 or s6
iNav does not allow resource mapping like Betaflight does. You will need to compile your own target to change pin assignments in the custom target you compile.
Unless you can do something with some custom Mixer but this will be complicated.
  Recently flashed INAV to speedybee f405 and already had issues on quad crash. grozaalex 0 537 03-May-2024, 09:25 PM
Last Post: grozaalex
  [SOLVED] Speedybee F405 Wing servos problem totor 1 3,041 26-May-2023, 02:47 PM
Last Post: totor
  magnetometer on Matek M8Q-5883 koklimabc 4 1,331 08-Mar-2023, 07:54 AM
Last Post: koklimabc
  GPS not working on Matek F405-WMN Aer0baticCat 4 1,143 10-Oct-2022, 02:09 AM
Last Post: matt0725
  12v LED PWM Switch INAV - Matek F722-WPX Simpo20 5 1,653 19-Jan-2022, 11:02 AM
Last Post: Simpo20
