Nazgul5 V2 bound but no input
First drone and am having issues with no input from my Frsky Xlite-S. The RXSR is bound however there is no input shown on betaflight. The RSXR is in SBUS(blue LED) as that is what has been suggested as a fix in previous forum posts. Anyone able to help?
Here's the dump: https://pastebin.com/YWKiB47X
Making some assumptions that you have the SBUS_OUT wire of the R-XSR connected to the RX1 pad on the FC, run the following commands in the CLI and then check for stick movements again in the Receiver tab...
set serialrx_halfduplex = OFF
save
There are stages to a full connection.
1. Tx bound to Receiver
2. Ports set on Flight Controller page in Betaflight, etc to enable the FC to understand where the Receivers output signal is expected to appear
3. What type of signal to expect on the configuration page.
3. On the receiver page, set up that the right TX stick moves the right control bar the required amount.
What BadRaven said...
On my Nazgul V2:
1 rsxr - led solid green
2 In ports tab > serial RX on UART 2
3 In config tab > Serial based + SBUS
4 self evident ;-)
But check if it's really bound first
  Help Crossfire Nano RX bound to Tango II but no sticks/switches input in BF nor IRL illumn` 4 323 31-May-2024, 10:23 PM
Last Post: illumn`
  NO RECEIVER INPUT IN BETAFLIGHT PLEASE HELP JakeTheNut 9 347 25-Apr-2024, 08:05 PM
Last Post: SeismicCWave
  [Solved] Don't get any input from ELRS receiver in BetaFlight aprudnikoff 4 534 03-Mar-2024, 01:03 AM
Last Post: aprudnikoff
  Solved Betaflight 4.5 elrs rx no sticks input Mad35 7 648 26-Jan-2024, 08:47 AM
Last Post: Mad35
  Help Radio Input Troubles heliphlier 4 424 06-Oct-2023, 02:24 PM
Last Post: heliphlier
