Threads: 33
Likes Received: 99 in 68 posts
Likes Given: 38
2 23-Aug-2020, 10:51 AM (This post was last modified: 23-Aug-2020, 10:53 AM by andreab.) Hi guys,
I noticed that most of the stacks have a male connector for the camera, and most of the camera have a male connector too.
I don't feel confident in playing with the JST, too small to me. What's the trick in this case? The camera connectors use pins too, not welded.
Thanks!
Andrea - "If you want to check your quad durability, let me fly (crash) it"
Threads: 50
Likes Received: 832 in 504 posts
Likes Given: 372
51 CLRacing used to sell packs of pre-crimped wires with a pile of JST-SH connectors so you could make your own.
https://uk.banggood.com/CL-RACING-JST-SH...rehouse=CN I found them on Amazon as well, but they look like they were drop-shipped from China anyway - delivery time was 3 weeks.
The ground is for dead people.
Threads: 33
Likes Given: 38
2 (23-Aug-2020, 11:18 AM)Banelle Wrote: CLRacing used to sell packs of pre-crimped wires with a pile of JST-SH connectors so you could make your own.
Thanks, that looks easier than crimp the cables by myself... just need to double check with JST size I do need.
Threads: 33
Likes Given: 38
2 23-Aug-2020, 11:35 AM (23-Aug-2020, 11:28 AM)SnowLeopardFPV Wrote: The other option is to get some JST-SH 1.0 pigtails, then cut the connector off the camera harness and splice/solder the ends together with some heat shrink sleeving for insulation over the joint.
Assuming your profile location is correct then you can get them locally and quickly from the following link, although this is a tad expensive (that is 1 pigtail for £1)...
https://www.hobbyrc.co.uk/jst-sh-3-pin-c...50mm-wires
A pack of 10 works out cheaper here per unit if you're prepared to wait for delivery...
https://www.banggood.com/10-PCS-AuroraRC...11496.html
Ok thanks. Assuming I'm going for the RunCam Racer Nano 2, I do need a 4 to 3 JST 1.0 cable. It would be nice to have it ready to use, but I'm asking too much
Threads: 587
Likes Received: 8,973 in 6,640 posts
Likes Given: 1,425
789 You can just ignore the 2-pin "Menu" connector plug on the harness that comes with the RunCam Racer Nano 2 (zip tie it out of the way). If you want camera control via the FC, the GEPRC Stable F11 FC doesn't have a dedicated camera control pad so you would need to remap another pad that has a timer associated with it for camera control (i.e. the LED pad). If you do this you will then need to solder the "MENU" pin from the camera connector direct to that pad on the FC.
Threads: 33
Likes Given: 38
2 23-Aug-2020, 12:04 PM (This post was last modified: 23-Aug-2020, 12:05 PM by andreab.) (23-Aug-2020, 12:01 PM)SnowLeopardFPV Wrote: You can just ignore the 2-pin "Menu" connector plug on the harness that comes with the RunCam Racer Nano 2 (zip tie it out of the way). If you want camera control via the FC, the GEPRC Stable F11 FC doesn't have a dedicated camera control pad so you would need to remap another pad that has a timer associated with it for camera control (i.e. the LED pad). If you do this you will then need to solder the "MENU" pin from the camera connector direct to that pad on the FC.
I don't need the FC control, but I assume I can't plug a 3 pin female connector into a 4 pin male connector. Or can I?
