my tango 2 is connect to Rx but in betafly there are no input
hi, I was new to the hobby and this is my first drone and i have a problem with my tango 2
[Image: tqCVZYBl.jpg]
[Image: 1GsODrVl.jpg]
[Image: 9gj7bpxl.png]
[Image: KkW43ywl.png]
I can’t make out your wiring since all the wires are black.
Double check you have Ch1 wired to FC RX and Ch2 wires to FC TX.
If that’s correct then try reflashing the firmware on the Micro RX and the Tango 2 and rebinding.
(23-Mar-2022, 10:48 PM)kafie1980 Wrote: I can’t make out your wiring since all the wires are black.
hi i will try it today thanks you for reply
so i install a new firmware for Micro RX and Tango 2 but none was work
Did you double check the connections? Can you test for continuity using a multimeter? Did you check the connector for any bent pins?
Whats FC do you have? Can you try another UART?
(24-Mar-2022, 10:11 AM)kafie1980 Wrote: Did you double check the connections? Can you test for continuity using a multimeter? Did you check the connector for any bent pins?
[Image: IHHACWRl.png]
this is the fc i using so i try all of the UART i will check for continuity  today
so i check for continuity and everything seem alright , i also do further my measuring the voltage this is what i got
GND= 5 v
channel 1= 1.5 -3.3v
channel 2 = 3.3v
and also i try all the UART none was working
also here are some of the pic of wiring
 [Image: XrRDzW1l.jpg]
[Image: 4pR25Y6l.jpg]
[Image: dPqJwxEl.jpg]
I seriously cannot clearly make out the wires. Its all black and I am unable to correctly follow them back to the pads. I am so used to looking at coloured wires.
Assuming everything else checks out then one last thing I can suggest is to re-flash Betaflight and ensure you do a full chip erase.
Do you happen to have any receiver to test? Your current receiver may be faulty.
Thanks i will try it today
  Help Issues Connecting TBS Nano RX and TBS Tango 1 DeerEdge 3 339 04-Jun-2024, 05:27 AM
  Help Crossfire Nano RX bound to Tango II but no sticks/switches input in BF nor IRL illumn` 4 333 31-May-2024, 10:23 PM
Last Post: illumn`
  tango 2 no telemetry screens cele_FPV 6 356 25-Apr-2024, 10:48 PM
  NO RECEIVER INPUT IN BETAFLIGHT PLEASE HELP JakeTheNut 9 353 25-Apr-2024, 08:05 PM
  [Solved] Don't get any input from ELRS receiver in BetaFlight aprudnikoff 4 551 03-Mar-2024, 01:03 AM
Last Post: aprudnikoff
