23-Mar-2022, 10:12 PM
hi, I was new to the hobby and this is my first drone and i have a problem with my tango 2
![[Image: tqCVZYBl.jpg]](https://i.imgur.com/tqCVZYBl.jpg)
![[Image: 1GsODrVl.jpg]](https://i.imgur.com/1GsODrVl.jpg)
![[Image: 9gj7bpxl.png]](https://i.imgur.com/9gj7bpxl.png)
![[Image: KkW43ywl.png]](https://i.imgur.com/KkW43ywl.png)
my tango 2 is connect to Rx but in betafly there are no input |
23-Mar-2022, 10:12 PM hi, I was new to the hobby and this is my first drone and i have a problem with my tango 2 ![]() ![]() ![]() ![]() 23-Mar-2022, 10:48 PM I can’t make out your wiring since all the wires are black. Double check you have Ch1 wired to FC RX and Ch2 wires to FC TX. If that’s correct then try reflashing the firmware on the Micro RX and the Tango 2 and rebinding. 23-Mar-2022, 11:19 PM (23-Mar-2022, 10:48 PM)kafie1980 Wrote: I can’t make out your wiring since all the wires are black.hi i will try it today thanks you for reply 24-Mar-2022, 08:24 AM (23-Mar-2022, 10:48 PM)kafie1980 Wrote: I can’t make out your wiring since all the wires are black. so i install a new firmware for Micro RX and Tango 2 but none was work 24-Mar-2022, 10:11 AM Did you double check the connections? Can you test for continuity using a multimeter? Did you check the connector for any bent pins? Whats FC do you have? Can you try another UART? 24-Mar-2022, 12:30 PM (24-Mar-2022, 10:11 AM)kafie1980 Wrote: Did you double check the connections? Can you test for continuity using a multimeter? Did you check the connector for any bent pins? ![]() this is the fc i using so i try all of the UART i will check for continuity today 25-Mar-2022, 08:06 AM so i check for continuity and everything seem alright , i also do further my measuring the voltage this is what i got GND= 5 v channel 1= 1.5 -3.3v channel 2 = 3.3v and also i try all the UART none was working 25-Mar-2022, 08:07 AM 25-Mar-2022, 02:15 PM I seriously cannot clearly make out the wires. Its all black and I am unable to correctly follow them back to the pads. I am so used to looking at coloured wires. Assuming everything else checks out then one last thing I can suggest is to re-flash Betaflight and ensure you do a full chip erase. Do you happen to have any receiver to test? Your current receiver may be faulty. 30-Mar-2022, 09:53 PM Thanks i will try it today |
Help Issues Connecting TBS Nano RX and TBS Tango 1 | DeerEdge | 3 | 332 | 04-Jun-2024, 05:27 AM Last Post: SeismicCWave | |
Help Crossfire Nano RX bound to Tango II but no sticks/switches input in BF nor IRL | illumn` | 4 | 329 | 31-May-2024, 10:23 PM Last Post: illumn` | |
tango 2 no telemetry screens | cele_FPV | 6 | 350 | 25-Apr-2024, 10:48 PM Last Post: SnowLeopardFPV | |
NO RECEIVER INPUT IN BETAFLIGHT PLEASE HELP | JakeTheNut | 9 | 350 | 25-Apr-2024, 08:05 PM Last Post: SeismicCWave | |
[Solved] Don't get any input from ELRS receiver in BetaFlight | aprudnikoff | 4 | 541 | 03-Mar-2024, 01:03 AM Last Post: aprudnikoff |
