28-Aug-2022, 06:33 AM
Hi there
I have some weird test results from testing around with my multimeter that I am having a hard time explaining.
Continuity on FC main battery leads:
+ multimeter to + FC and - multimeter to - FC: no beep, OL
+ to - and - to + or "reversed": no beep but shows 0.582 (ohms? kohms?) of resistance
It seems like when I hook up the multimeter to match the polarity, I get no continuity. But when I "reverse" the polarity I get some sort of continuity.
Continuity between + and - of my vtx (RMRC 800mw 1.2 ghz):
Either way I touch the leads, I get a beep and resistance reading of 0.006
My questions:
1) how come the FC has no continuity one way and continuity the other way (unless the no beep on the "reversed" connection signifies no continuity, if so then why is there a resistance reading?)
2) Is it normal for the vtx to have continuity across + and -. In a way it makes sense because there are no physical switches or components preventing the circuit from closing once the power source is connected. I have already powered up the FC and vtx and can confirm everything is working but would still like to know.
Thanks to whoever can help answer
My questions:
