Mounting those tiny ELRS antennas on larger quads
Ahoy guys, just a quick question.
I'm making the jump on ELRS as the control link on a larger quad.
At the moment they have all been crossfire running on a QX7 but with my new TX being this: Tongue
[Image: attachment.php?aid=8442]
I'm now rocking an xlite pro with HM ELRS PRO nano module TX.  Cool This TX is a thumber's wet dream, lol..
I trust this TX more than my jumper t-lite and its crappy battery bay.
So I'm in the midst of rebuilding my badger 6" frame due to a nasty crash.   Gumtree 1, badger 0 Sad
I'm wondering where to mount these pissy little 2.4GHz antennas.   I'd thought I would go with an arm mount, staying away from the VTX components.   These antennas a no immortal-T's like crossfire, they are VERY much mortal... (see what I did there? lol...)
Here's where I'm going with the placement for now:
[Image: attachment.php?aid=8441]
Two zipties for rigidity and I will most likely heatshrink the dipoles with a piece of plastic as a splint/brace for strength.   Already though I don't like it....
What's everyone's thoughts on mounting a ELRS 2.4GHz antenna on a large(ish) quad like this 6" badger frame by armattan?
Cheers,
ph2t.
Attached Files Thumbnail(s)
My preference would be to design a 3D printed mount and mount it off the back. If you're worried about the frame blocking the antenna elements then mount it at an angle so the antenna clears the frame / LiPo. I've also seen a few people cable tie them to the VTX antenna like the following which apparently works fine without any signal interference issues from the VTX antenna or vice versa.
[Image: nMRAVzPl.jpg]
  • ph2t
Thanks Snow. Unfortunately I don't have access to a 3d printer anymore, I changed jobs last year. I didn't realise that ELRS doesn't interfere with video, I thought all control links that have telemetry would cause some interference (ala crossfire).
Telemetry links do not cause issues on all setups. 5 out of 6 quads I currently have do seem to be affected by the telemetry issue. The only odd one that does only does it on a mini immortal-T.
Try placing the antenna close to the VTX antenna and see if you get interference else mount it elsewhere.
Actually on the Armattan Badger I thought we can mount it below the camera cage with zip ties but aluminium is more conductive than carbon and you better test it first.
I have a crappy roll of black TPU left but works well enough for simple mount designs on my Ender 5 bowden setup. If you have a design you like on thingiverse then I am happy to print a mount and post it to you.
[-] The following 1 user Likes kafie1980's post:
  • ph2t
Thank you Kafie, that is very generous mate! I will hopefully test today, bloody crappy weather....
The wet weather over SA has not been any better. Miserable to go out and fly.
(05-Jun-2022, 02:36 PM)ph2t Wrote: Thanks Snow.  Unfortunately I don't have access to a 3d printer anymore, I changed jobs last year.   I didn't realise that ELRS doesn't interfere with video, I thought all control links that have telemetry would cause some interference (ala crossfire).
Below is a link to the thread on Facebook where the photo in my previous post came from. If you read through the comments you can see the poster stating he/she has no interference issues with it mounted like that. There have been other similar posts in the past showing the same mounting technique but once a week has passed there is virtually no chance of finding them again in the crappy FB interface.
https://www.facebook.com/groups/FPVLIFE/...5788791282
Congratulations on the job change (assuming it was by choice). Now you have an excuse to get your very own 3D printer Big Grin
(05-Jun-2022, 02:11 PM)SnowLeopardFPV Wrote: My preference would be to design a 3D printed mount and mount it off the back. If you're worried about the frame blocking the antenna elements then mount it at an angle so the antenna clears the frame / LiPo. I've also seen a few people cable tie them to the VTX antenna like the following which apparently works fine without any signal interference issues from the VTX antenna or vice versa.
I have my ELRS antenna mounted like shown in the picture above.  So far with about 30-40 flights under my belt there has been no issues with interference.
  ELRS : Dynamic Tx Power and True Diversity Receivers Alex Red 4 137 23-Jun-2024, 08:15 AM
Last Post: Alex Red
  ELRS dipole antenna orientation - horizontal or vertical mstc 19 504 17-Jun-2024, 08:51 PM
Last Post: MomoBrut
  Weird RXLOSS ELRS issue Pathfinder075 8 247 06-Jun-2024, 09:51 PM
  Help Super X V1 Bricked ELRS Caelus_fpv 11 604 04-Jun-2024, 03:37 PM
Last Post: Caelus_fpv
  ELRS 3.4.1 - massive problems after turning off model matching Imp 3 208 30-May-2024, 06:14 PM
Last Post: SeismicCWave
