Threads: 589
Likes Received: 8,983 in 6,648 posts
Likes Given: 1,426
789 I have a GEPRC Phantom and I personally wouldn't put a GPS module on it. It's a tiny 2.5" quad which is already quite heavy for it's size so adding additional peripherals like a GPS module is just going to make it less pleasant for flying freestyle with. While the FC does have two hardware UARTs, the second one is hardwired to the VTX via header pins between the boards for IRC Tramp control, so you can't easily repurpose that UART for something else.
There also aren't enough available spare output pads that can be remapped to SoftSerial so you don't even have that option. The bottom line is that unless you swap the Stable F411 Stack for something else or you are skilled enough to solder directly to pins on the F411 MCU then you aren't going to be able to put a GPS module on a GEPRC Phantom that comes as a BNF version. Of course, you could just buy the frame and build your own with your own choice of FC, but it doesn't sound like you want to do that.
Based on what you said, I would just get the Flywoo LR V2 instead.
Threads: 47
Likes Received: 2,782 in 2,244 posts
Likes Given: 7,678
97 +1 I agree with SnowleopardFPV. Yeah, just get the Flywoo LR V2.
I also have a GEPRC Phantom and would not put a GPS unit on it.
It is not about the mounting as that could easily be accomplished.
Just a note about RTH. It works {or doesn't depending on your perspective}
the same with any quad that is running Betaflight; regardless of brand or
even if you DIY the GPS or do a build. From everything that I have seen,
Betaflight's RTH feature is rudimentary.
If you really want good RTH, then you would need to consider iNav.
