motors not spinning using dshot
Ні!
I recently bought a "GOKU F7 MINI V2 40A BLS 20X20 STACK FLIGHT CONTROLLER"
https://flywoo.net/products/goku-f7-mini...controller
It's a stack with a 4in1 ESC:
https://flywoo.net/products/goku-406s-8bi-2-6s-
esc-20×20
purchased as a kit
The ESC came with bluejay installed, I also tried BL HELI S since it supports this.
But I can't get the motors to spin, not in betaflight, not in the blheli config. Only way the motors spin is in any other protocol than DSHOT.
When I connect the radio and arm the drone it says
"MOTOR_PROTOCOL" in betaflight as the reason why it won't arm. No motor protocol selected, or something along those lines. Even though I have DSHOT selected.
With multishot they move. like shit. but they move.
Could anyone help me out? just tell me what information you need and i'll get it.
Thanks!
Are you running BF 4.5.0? There seems to be an issue with this BF version and the F722 processor preventing motors from spinning
https://github.com/betaflight/betaflight/issues/13598
This issue is supposed to be fixed in 4.5.1 and not existing in 4.4 or previous version. Otherwise you can try setting DSHOT_BITBANG = OFF and see if that works for you, although not sure if that will affect bi-directional dshot or not.
  • V-22
(28-Jun-2024, 09:32 PM)mstc Wrote: Are you running BF 4.5.0? There seems to be an issue with this BF version and the F722 processor preventing motors from spinning
This is probably the issue.
@nckhvlk I would flash back to Bluejay (48kHz PWM) and then make sure both dshot bitbang and bidirectional dshot are enabled in Betaflight:
set dshot_bitbang = ON
set dshot_bidir = ON
save
You should also be using DSHOT300 and a 4kHz PID loop rate.
  • hugnosed_bat
  Default BetaFlight 4.5 motors run hot EyeBotXander 35 928 20-Jun-2024, 08:40 PM
  Low performance on DShot 600 duschkopf 2 296 02-Jun-2024, 01:23 PM
Last Post: duschkopf
  Can $5 motors be any good? 1805-1550kv mstc 22 489 01-Jun-2024, 11:26 PM
  Help Motors not spinning polar223 16 607 31-May-2024, 09:50 PM
  Motors spin rough then stop MajorKook 4 172 18-May-2024, 08:53 PM
Last Post: MajorKook
