Posts: 5,323 Threads: 674 Likes Received: 3,160 in 1,747 posts Likes Given: 2,032 Joined: Jan 2016 Reputation: 139 15-Jan-2019, 11:59 PM (This post was last modified: 15-Jan-2019, 11:59 PM by Oscar.) Just got these in, don't they look pretty? I was told metal capped MOSFET runs cooler than traditional fets, so that's something to look forward to when testing these Now we can monitor ESC temperature through telemetry By the way these are 60A ESC (continuous) so should be able to take some pretty bad abuse! Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 • Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 Nice! iFlight seems to be come onto the scene with some quality products at a reasonable price. I just picked up one of their 7" XL frame and for an under $40 frame, the quality is excellent Dude, where's my quad? • Posts: 1,013 Threads: 11 Likes Received: 452 in 349 posts Likes Given: 372 Joined: Dec 2017 Reputation: 16 Does look nice. I just checked out their website and saw the Succex 50A slick esc's. They will fit in the wire grooves of my Fossils stuff Gravity frame to protect from a prop strike. May have to try them out. • Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 Nice, but at well over $100 by the time it arrives at my door, I'll pass Dude, where's my quad? • Posts: 545 Threads: 28 Likes Received: 135 in 101 posts Likes Given: 94 Joined: Oct 2018 Reputation: 6 Sure look's like a stunner, Hope those mosfets don't short because of the metal. I mean it's conductive, right? Wet grass or something like that and it's gone... • Posts: 21,274 Threads: 587 Likes Received: 8,970 in 6,638 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 (17-Jan-2019, 09:37 AM)brnmd Wrote: Sure look's like a stunner, Hope those mosfets don't short because of the metal. I mean it's conductive, right? Wet grass or something like that and it's gone... No. The metal is a heatsink "cap" over the top of each MOSFET. Underneath will be non-electrical conductive thermal paste between the cap and the MOSFET. The caps will likely be pretty well sealed on so that no water can get under them to the MOSFETs. While there are no guarantees, the MOSFETS themselves should be far more resilient to moisture than normal ESCs which have all their pins exposed are. Posts: 5,323 Threads: 674 Likes Received: 3,160 in 1,747 posts Likes Given: 2,032 Joined: Jan 2016 Reputation: 139 (17-Jan-2019, 09:37 AM)brnmd Wrote: Sure look's like a stunner, Hope those mosfets don't short because of the metal. I mean it's conductive, right? Wet grass or something like that and it's gone... It's just a metal cap, like a heatsink • Posts: 58 Threads: 15 Likes Received: 30 in 16 posts Likes Given: 41 Joined: Sep 2018 Reputation: 1 (16-Jan-2019, 02:43 AM)RENOV8R Wrote: Nice! iFlight seems to be come onto the scene with some quality products at a reasonable price. I just picked up one of their 7" XL frame and for an under $40 frame, the quality is excellent I got their XL5 5-inch frame recently and can also say it's quite polished for the money. Granted I don't have very high standards since this frame replaced my busted Wizard x220s frame, which is my first and only carbon framed quad (not to mention weak AF). iflight seems to have the most consistently good selection on quad parts on Amazon with decent (albeit infrequent) reviews. If you just need a basic replacement part asap without waiting a decade on shipping, iFlight seems to do the job beautifully. • Posts: 52 Threads: 2 Likes Received: 28 in 23 posts Likes Given: 1 Joined: Mar 2018 Reputation: 2 Oh Im using one of these beautys on my 7in Really dont want to solder it since its so pretty Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 19-Jan-2019, 04:28 AM (This post was last modified: 19-Jan-2019, 04:29 AM by RENOV8R.) (19-Jan-2019, 02:01 AM)Apple Wrote: Oh Im using one of these beautys on my 7in Really dont want to solder it since its so pretty Tip for soldering: It has the perforated pads so flip it upside down and apply solder to the pads with high heat(400C). The solder will flow through and when you flip it over, you'll have the perfect solder dome to solder your motor wires to. Dude, where's my quad? Posts: 5,323 Threads: 674 Likes Received: 3,160 in 1,747 posts Likes Given: 2,032 Joined: Jan 2016 Reputation: 139 (19-Jan-2019, 04:28 AM)RENOV8R Wrote: Tip for soldering: It has the perforated pads so flip it upside down and apply solder to the pads with high heat(400C). The solder will flow through and when you flip it over, you'll have the perfect solder dome to solder your motor wires to. excellent tip, not a lot of people mention this in fact • Posts: 52 Threads: 2 Likes Received: 28 in 23 posts Likes Given: 1 Joined: Mar 2018 Reputation: 2 Ok just as a heads up I noticed that the esc cable I received is not color coded correctly. Black and red for ground and voltage are flipped so they match up with telemetry and current. Doesn't matter much since you should double check pinouts any way. Just don't magically assume black goes to ground. |
