Mamba F405 mk2
Hi All,
I’m running the latest betaflight, and just re flashed my mamba f405 mk2 to the latest firmware and my leds do not light up, if I re flash it with the legacy firmware the leds work but then I can’t set my motor output and a few other things the latest offers, if I use any other firmware later then the legacy only one led on each are lights up. Has any one experienced this ? Thanks
The Mamba F405 MK2 uses the FURYF4OSD Betaflight target, so make sure that is the one you are flashing to the FC and not one of the MAMBAF405US targets. Then when first connecting to the FC after flashing, make sure you click on the "Apply Custom Defaults" when that prompt appears.
Hi yes I’ve done all that, I’ve also tried different firmwares for the furyf40Sd only the legacy on makes all the led light up, if I use one from the middle of the options, I get one led on each arm blinking
Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
Please also post some good clear photos of the actual wiring so we can see how everything is wired up.
[Image: n7uusB1l.jpg]PLEASE FIND ATTACHED HOPE THIS HELPS[Image: l2iRWoFl.jpg][Image: baqDtLCl.jpg][Image: lRSK3W2l.jpg]
(17-Mar-2022, 10:33 PM)SnowLeopardFPV Wrote: Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
(18-Mar-2022, 12:00 AM)rayb106 Wrote: [Image: n7uusB1l.jpg]PLEASE FIND ATTACHED HOPE THIS HELPS[Image: l2iRWoFl.jpg][Image: baqDtLCl.jpg][Image: lRSK3W2l.jpg]
.txt   BTFL_DUMP_ALL_cli_Vampire_2_20220314_212419.txt (Size: 35.43 KB / Downloads: 140)
.txt   BTFL_DIFF_ALL_cli_Vampire_2_20220314_212346.txt (Size: 3.25 KB / Downloads: 118)
All of your settings look fine. Looking through the GitHub issues I see that someone opened an issue describing a similar (or the same) problem but they then closed the issue without saying why they had closed it. See the link below...
https://github.com/betaflight/betaflight/issues/10871
So it looks like there could well be a bug in the FURYF4OSD Betaflight target when using the LED_STRIP functionality. I would therefore suggest that you raise an issue for your problem on GitHub so that one of the Betaflight devs can look into it...
  Speedybee F405 v3 blackbox error BF4.5 az.lonewolf81 2 108 30-Jun-2024, 12:19 PM
  Mamba Stack - DJI F405 MK2 FC with ibus mj451971 7 538 03-Jun-2024, 10:01 PM
  SpeedyBee F405 V3 Testing Motors (Not Spinning) angent56 20 3,037 07-May-2024, 02:53 PM
Last Post: mstc
  Mamba Mk5 F435 Stack - Anyone running one? Pathfinder075 7 896 18-Apr-2024, 02:55 PM
Last Post: punkkone
  Help Problem accessing the ESP8285 chip on MATEK FC F405 WTE remi.auge 2 370 05-Mar-2024, 12:49 PM
Last Post: remi.auge
