22-Aug-2020, 02:48 AM (This post was last modified: 29-Oct-2020, 12:37 PM by iFly4rotors.)
2020-08-21 Katana-LR5x (Long Range 5 inch) My fifth (5th) Build My Journal
Last Post
The Katana-LR5x (Long Range 5 inch) is my fifth (5th ) build and is a Long Range quad. The "x" designator indicates that this is an experimental build. Once the original configuration is built, tested, and flown for a while; the quad will be used to test various components and perhaps combinations {even including, perhaps, adjustments to the frame}. First, the frame kit (TomoQuads, Katana 2, the 5 inch version) appears to be identical to the Katana 2, 4 inch except that the arms are longer. My intention is to use the same electronic components that are in the Katana-LR4 build except for larger motors and props. So...I will only post pictures of parts that are different or lend added value in this thread.
Specifically, I have some FPV Cycle {KababFPV} 2203 3450kv T-Mount motors that I want to try. These motors are red and white and look really cool . They are heavy at 20g per motor so I hope they perform well. I will try other motors as we move along.
I will update this post with parts as I receive or change them until the initial build is complete. The post will then be a complete parts list for reference. The actual build will be put in other posts as things are completed.
NOTE: Misc parts, bolts, connectors, fabricated plates, columns, wire, etc. will NOT be included.
____________ PARTS LIST ____________ {will update as needed until build is complete}
Frame: Katana 2, 5" version, color = Red Here at TomoQuads
FC: JHEMCU GHF411 30A AIO {2020-08-30} Here at FPV Cycle
FC: JHEMCU GHF405 25A AIO {2020-08-30} Here at PyroDrone
Motors: FPV Cycle 2203 3450kv T-Mount Here at FPV Cycle
Props: HQProp Durable Prop T5x3 Grey; Model T5x3GR-PC Here at PyroDrone
VTX: Flywoo GoKu TX-Nano 450mw Here at PyroDrone
VTX Antenna: VAX Minion Pro {2020-08-30} Here at PyroDrone
Camera: Foxeer Razer Nano 1200TVL Here on AMAZON
Rx Receiver: FrSky R9MM {will wire as SBUS} **
RX Antenna: FrSky 900Hz Dipole T IPEX 4 {2020-08-30} Here on AMAZON
GPS: Matek M8Q-5883 Here at PyroDrone
Capacitor: Sanyo 1000uf 35v Here on AMAZON
** These are ACCST {NOT the ACCESS ones} that I bought before they were all sold out.
{2020-08-22} Update: Added some pictures: 0001, 0002, 0003.
After unpacking the flight controllers, I have two different JHEMCU FCs; a GHF411 and a GHF405. Reference the 0003 picture. the GHF405 has more UARTS, bigger motor mount pads, and the other pads are spaced out better {yeah, you can read the pad information a lot better, too} ...so... I think that I will use the GHF405 25A flight controller.
{2020-08-30} Update: Added picture of VTX, VTX antenna, R9MM with antenna attached.
I did use the GHF405 25A flight controller. This board is actually easier to work on, and it has more free UARTS than the GHF411 30A flight controller. Thanks to SnowLeopardFPV, I was able to fully connect the GPS unit including the compass feature: [HELP] GPS - Wiring the Compass on Matek M8Q-5883
{2020-09-01} Update: Added some pictures.
The build is now complete. The AUW with a 3s 650mAh GNB battery is 241 grams.
I will update this thread with flight videos, test results, and any changes or upgrades to the craft.
Jump to the most recent post HERE
Last Post
