Kakute F7 Aio Current sensor
Hi
I have a problem with amps draw, in osd i always see 0.6 amps doesnt matter what im doing, voltage works, mah works
Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
(11-Dec-2020, 02:06 PM)SnowLeopardFPV Wrote: Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
https://pastebin.pl/view/d71bd88e
Run the following CLI commands and that should solve your issue...
set current_meter = ADC
save
(11-Dec-2020, 03:35 PM)SnowLeopardFPV Wrote: Run the following CLI commands and that should solve your issue...
save
With esc current meter i see 0A with ADC current meter i see still 0.6amps not moving
(11-Dec-2020, 03:42 PM)Nikoo Wrote: With esc current meter i see 0A with ADC current meter i see still 0.6amps not moving
OK. I can see nothing else wrong with any of your other dump file settings.
There have been some issues with some of the Kakute F7 boards and the current sensor, so maybe yours is unfortunately one of those.
Try re-flashing the firmware with "Full chip erase" switched on. If that doesn't fix the issue then I have no other suggestions other than to contact the vendor and try to get a replacement FC under warranty.
  New Product Another AT32 AIO but dedicated to digital mstc 29 2,538 10-Jun-2024, 12:30 AM
  New: goku gn745 45a aio bl_32 mpu6000 v3 skywanderer 2 270 19-May-2024, 07:03 PM
Last Post: skywanderer
  Help happymodel superx AIO Voltage Fluctuations Caelus_fpv 6 384 18-May-2024, 09:39 PM
Last Post: Caelus_fpv
  Help Darwin 15A AIO - ESC Issue Pathfinder075 22 500 16-May-2024, 06:42 AM
  JHEMCU GHF745 HD AIO F7 OSD Flight Controller and Built-In 40A BLHeli32 3-6S FC husafreak 14 504 10-May-2024, 03:12 PM
Last Post: husafreak
