  • 1 Vote(s) - 5 Average
It's happening!! [Martian II][Apicalis first build]
#31
How did you test the motors? If it's a noise issue messing up the gyro / PID, then theoretically the clicking shouldn't happen when you only test from motor tab (not armed by tx).
If it's still present hmmm... maybe add the signal ground wires? Oh, and grisha0's signature comes to mind Wink ("have you added low-esr capacitors?")
#32
Come on guys! Let's try to hold off on the f-bombs, alright?! (This is not just to you Apicalis - but I gotta start saying something when I see it.)
EDIT: I'm serious guys - this is to everyone!!!
  • RENOV8R
#33
(22-Apr-2017, 12:51 AM)fftunes Wrote: How did you test the motors? If it's a noise issue messing up the gyro / PID, then theoretically the clicking shouldn't happen when you only test from motor tab (not armed by tx).
The caps that I added are low esr 470uF 25V. Yeah the signal ground wires definetly come to mind.
(22-Apr-2017, 01:01 AM)sloscotty Wrote: Come on guys! Let's try to hold off on the f-bombs, alright?! (This is not just to you Apicalis - but I gotta start saying something when I see it.)
Understood captain *salutes*
Sadly I have to help my best buddy move today so I am probably not able to check on my quad Sad
I like turtles
#34
(21-Apr-2017, 10:04 PM)Apicalis Wrote: But do your quads also make a clicking noise when they brake? I mean normal motor brake. Max throttle -> no throttle
Sorry, but no, I've never heard a motor make noises like yours do when throttling down. Not on any of my builds.
Maybe it's nothing. Maybe it's just a 'feature' of these motors. In the end, it's whether it flies that's the measure you're interested in.
#35
But i have to ask again just to make sure - did you spin up the motors only by motor tab sliders too while transmitter is turned off? Just because in your videos you always seem to use transmitter throttle stick... which opens up the range of possible issues to PID / filtering / physical noise / electrical noise.
#36
(22-Apr-2017, 10:02 AM)unseen Wrote: Sorry, but no, I've never heard a motor make noises like yours do when throttling down. Not on any of my builds.
That's an information I have been waiting for. Like u said, it might be normal with these motors but I can't imagine that. I will definetly check them again, mechincal wise and also the resistance of the windings.
(22-Apr-2017, 11:21 AM)fftunes Wrote: But i have to ask again just to make sure - did you spin up the motors only by motor tab sliders too while transmitter is turned off? Just because in your videos you always seem to use transmitter throttle stick... which opens up the range of possible issues to PID / filtering / physical noise / electrical noise.
I think not after I put on the props for the first time. I gotta try that again. But I am very sure that before I calibrated the ESCs, the exact same noises came mid throttle while i throttled up in betaflight (not the remote). Anyways I will definetly try that again
I like turtles
[-] The following 1 user Likes Apicalis's post:
  • unseen
#37
IT'S DONE!!!! It's finally working properly!!!
I've checked all the motors mechanically and tested the resistance of the windings (all were 0.2 Ohms). After that I decided to recalibrate the ESCs since I remember that after switching the rotation direction of two motors I hadn't done that.
And ... it works like a charm now!!! I am absolutely excited and really pleased with the results and it looks beautiful imo. I really dig all the purple parts
Only thing to fix now is the Noise in the Video feed which is of course a rather easy fix Smile
My big thank u video Big Grin
A little punchout
Some hovering and a punchout
I was so emotionally down because of the motor issues so it was an absolute relief to be able to fly properly and enjoy it since I put so much work into it
I like turtles
[-] The following 6 users Like Apicalis's post:
  • RENOV8R, Grisha0, fftunes, Drone0fPrey, Carl.Vegas, unseen
#38
Great! Do the motors still sound strange?
Your second video is set as private.
#39
No weird noises anymore! I am so damn happy!!
Yeah i fixed the private issue thx
I like turtles
  • unseen
#40
That's great! Hey, you might not have to remove your minimOSD to configure MWOSD - you can do it through Clean/BetaFlight. See this thread: http://intofpv.com/t-configuring-mwosd-w...leanflight
#41
Looking at your first video, I can make a couple of suggestions about helping your video noise problems.
First off, twist the video and ground leads together both from the camera to the flight controller and from the flight controller to the VTX. Secondly, make sure you route the wires away from the beeper and any current carrying parts of the quad.
From the looks of it, your ESCs are only separated from the arms by the heatshrink. Do yourself a favour and re-mount them on some double sided sticky foam pads. If you don't, the vibration from the arms will eventually start to crack the ceramic capacitors. When that happens, the ESC will burst into flames! Big Grin
Don't tie wrap them down too hard either, if you pull the ties too tight, you'll be bending the ESC and they really don't like that.
  • Apicalis, Carl.Vegas
#42
(23-Apr-2017, 12:44 PM)Apicalis Wrote: IT'S DONE!!!! It's finally working properly!!!
Congrats! It looks great and definitely packs a punch. It seems in your 3rd video that there was some company in the air nearby somewhere (Can hear a helli flying)
carl.vegas
#43
(23-Apr-2017, 01:07 PM)sloscotty Wrote: That's great! Hey, you might not have to remove your minimOSD to configure MWOSD - you can do it through Clean/BetaFlight. See this thread: http://intofpv.com/t-configuring-mwosd-w...leanflight
I have a second minimOSD (accidently ordered 2) that I am currently trying to setup before I do anything on the actual quad. So far I am appearently to stupid to get it to work. This is my separate thread about it
http://intofpv.com/t-microminimosd-not-programmable
(23-Apr-2017, 01:11 PM)unseen Wrote: Looking at your first video, I can make a couple of suggestions about helping your video noise problems.
Yeah I left them long for the first try and didn't twist them yet. I will shorten them tomorrow i guess and twist them Smile
Great advice on the ESCs. I definetly tied them down to hard. Absolutely didn't think about the forces that impact on the whole quad. Even if no caps break the copper lines on the PCB might break etc. that's a very serious issue. Thank you for the hint!
(23-Apr-2017, 02:09 PM)Carl.Vegas Wrote: Congrats! It looks great and definitely packs a punch. It seems in your 3rd video that there was some company in the air nearby somewhere (Can hear a helli flying)
It's a small airport about 5km away. I think it was actually a single engine plane flying around approx 2-3km away. I of course don't intend to disturb air traffic and it was just a short flight.
Especially since the german GSG-9 Special police forces start their helicopters from there. It's their homebase.
I like turtles
  • unseen
#44
Looks great! Gotta love it when all the hard work (well, it's not really work) pays off. One simple tip on the ESCs, heat up the zip-ties a bit first. They'll adhere to the contours of the ESCs much better without putting much pressure on them.
#45
(24-Apr-2017, 01:28 PM)RENOV8R Wrote: Looks great! Gotta love it when all the hard work (well, it's not really work) pays off. One simple tip on the ESCs, heat up the zip-ties a bit first. They'll adhere to the contours of the ESCs much better without putting much pressure on them.
Already did that when i first tied them up. But still used a lot of strength so I will redo that
I like turtles
  Build Micro Apex 4" Build drumgod 10 485 Today, 01:45 AM
Last Post: drumgod
  Build Rekon5 UL 5" build ph2t 51 8,083 12-Apr-2024, 02:26 AM
Last Post: ph2t
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 12 1,898 25-Mar-2024, 10:28 PM
Last Post: Recursion
  Build 5in lightweight build hawk01 37 1,424 22-Mar-2024, 10:56 AM
Last Post: Jossey
  Build Whoosh - 3.5" build. PID settings? maxer 23 1,208 30-Dec-2023, 08:29 PM
