01-May-2019, 09:27 PM
Hey all. This is only my second so I am still learning a bit.
Did I do this right?
![[Image: Build-A01.jpg]](https://i.ibb.co/pdMpQpb/Build-A01.jpg)
Thank you so much for any help
Is my wiring correct? |
01-May-2019, 09:27 PM Hey all. This is only my second so I am still learning a bit. Did I do this right? ![]() Thank you so much for any help 01-May-2019, 10:55 PM (This post was last modified: 01-May-2019, 11:06 PM by SnowLeopardFPV. Edit Reason: Added a link to the F.PORT firmware. ) Wiring comments:-
Code: set serialrx_provider = FPORT 01-May-2019, 11:21 PM Round 2 Snow Leopard - I will have to look into this and thank you so much for the advice on that. "I would probably advise that you run F.PORT with the R-XSR. Flash F.PORT firmware to the receiver and then just connect the S.PORT pin of the R-XSR to the T2 pin as already shown on your diagram. Then you don't need to don't bother with a connection from the SBUS pin (just leave it disconnected). F.PORT firmware can be download from HERE. Just use the latest version (which as of today is 190311)." If you click on it, it gets bigger ![]() 01-May-2019, 11:25 PM No probs. Your other picture was actually fine. You just needed to click on it and it filled more than a 24" wide screen could handle. I think the issue is sometimes with people using tablets and phones because the picture viewer used by the forum doesn't easily allow you to zoom in to make it a bigger size that the tablet/phone screen. There are no such problems when using a web browser on a PC or Mac. Yeah, no worky on my PC or phone. My PC is Win 10, so it's not like I'm using some old system. I brought this issue up 6 months ago and got told to go sit in the corner, kind of like today. So, it still doesn't get any bigger....decided to just live with not being able to see pics bigger. Usually not a problem. But clearly something is wrong.....on my end apparently ![]() ![]() It's weird, no other forums I go to have this issue, even those that use MyBB format. Also with this page only, when I type on a post on my phone I get multiple characters like I'm stuttering.....I didn't dare bring the phone stuttering thing up, I don't like sitting in the corner. ![]() ![]() ![]() 02-May-2019, 01:06 AM (02-May-2019, 12:46 AM)Krohsis Wrote: Yeah, no worky on my PC or phone. My PC is Win 10, so it's not like I'm using some old system. Don't worry you're not alone. ![]() Perhaps this link? https://ibb.co/JqW4vVm or this one? https://drive.google.com/open?id=1D4sPpF...WY3p6lfaKd 02-May-2019, 02:14 AM (02-May-2019, 02:09 AM)silpheedx Wrote: Perhaps this link? Works much better, I agree with SnowLeopard 02-May-2019, 02:14 AM (This post was last modified: 02-May-2019, 02:17 AM by SnowLeopardFPV.) (02-May-2019, 02:09 AM)silpheedx Wrote: Perhaps this link? Just one thing I noticed on your new image. If you use F.PORT firmware with the S.PORT pin on the RX connected to the T1 pad on the FC, you set Serial RX of UART1 to be ON and you disable SmartPort (so the settings on your image are wrong). While F.PORT uses the S.PORT pin, it doesn't use the SmartPort protocol, so UART1 just needs to be enabled for standard RX data transmission. Also, you don't connect the SBUS OUT wire to R1 if you use F.PORT, so lose that grey wire. Turn off smart port telemetry on port 1. You don't need it when using F. Port. Edit: snow got to it before I did. 02-May-2019, 03:36 AM Interesting some are having issues with the pictures. Fine for me on a Windows 7 pro machine and Chrome. 02-May-2019, 04:37 AM I am running Windows 10 and Chrome or Edge without issue. Android and Chrome app also is fine. |
![]() | HGLRC M100-5883 Wiring Fault | Coleon | 6 | 546 | 22-Feb-2024, 10:03 PM Last Post: iFly4rotors |
![]() | Noob Wiring Omen???? | Coleon | 4 | 242 | 10-Feb-2024, 01:44 AM Last Post: iFly4rotors |
rush tank 2 ultimate wiring help to argus f7 pro | Dice | 1 | 212 | 21-Jan-2024, 12:09 AM Last Post: matt0725 | |
Wiring ZOHD kopilot with PWM ELRS RX (R24-P) | versus | 3 | 1,458 | 26-Aug-2023, 02:53 AM Last Post: mstc | |
Wiring help Buzzer/LED to Mamba F722 Mini MK4 | Cantan | 2 | 501 | 15-Aug-2023, 01:10 PM Last Post: Cantan |
