11-Oct-2021, 01:31 AM
i GET ERROR "INVALID SETTING GYRO_HARDWARE_LPF
NOTHING STANDS OUT AS A PROBLEM. ANY IDEAS. IT HAS GREYED MY HAIR A LITTLE.
INAV 3.0 ERROR NO ARM |
11-Oct-2021, 01:31 AM i GET ERROR "INVALID SETTING GYRO_HARDWARE_LPF NOTHING STANDS OUT AS A PROBLEM. ANY IDEAS. IT HAS GREYED MY HAIR A LITTLE. 11-Oct-2021, 03:31 AM Go to the CLI and type the following command: get gyro_hardware_lpf What value do you see there? 12-Oct-2021, 12:32 AM 12-Oct-2021, 03:13 AM try setting gyro_hardware_lpf to an allowed value: 256HZ, 188HZ, 98HZ, 42HZ, 20HZ, 10HZ depending on your build. 256HZ should be the first value to try just to see if you can arm. 12-Oct-2021, 05:59 AM (12-Oct-2021, 03:13 AM)kafie1980 Wrote: try setting gyro_hardware_lpf to an allowed value: 256HZ, 188HZ, 98HZ, 42HZ, 20HZ, 10HZ depending on your build. please specify the exact command set gyro_hardware_LPF 256HZ not accepted nor any other variants I could think of set 256HZ Quote:set gyro_hardware_lpf = 256HZ Did you use the equal to sign? "=" 12-Oct-2021, 08:46 PM (12-Oct-2021, 07:19 AM)kafie1980 Wrote: Did you use the equal to sign? "=" accepted w =. Tried down to 98HZ value but still get ###ERROR: invalid setting: gyro_hardware_lpf line above Arming disabled flags: RX THR CLI SETTINGFAIL COULD THIS BE A BAD FC/ GYRO OR WHAT. i REALLY DONT KNOW. SUDDENLY ALL IS DIFFERENT. LOOKING AT MY SETUP PAGE EVERYTHING READY TO GO LAST LINE: VTX NOT DETECTED YET IT WORKS FINE 12-Oct-2021, 10:18 PM Can you post a full `dump` and `diff all`? Also, what FC are you using? 13-Oct-2021, 11:45 PM (12-Oct-2021, 10:18 PM)V-22 Wrote: Can you post a full `dump` and `diff all`? FC Matek 722 SE 14-Oct-2021, 03:51 PM Try reflashing iNav making sure "Full chip erase" is checked and see if the error is still there before applying any of your settings. 15-Oct-2021, 04:16 AM (14-Oct-2021, 03:51 PM)V-22 Wrote: Try reflashing iNav making sure "Full chip erase" is checked and see if the error is still there before applying any of your settings. full chip erase is set. Trying to reflash boards from 3.01 to 3.02 not successful. Cannot obtain DFU Windows does not recognize driver - error. Updated Zadig to 2.6 Loaded drivers shown but windows wont accept any of them same error message. Would a Mac computer work better 17-Oct-2021, 02:08 PM (15-Oct-2021, 04:16 AM)rgtoth Wrote: full chip erase is set. Trying to reflash boards from 3.01 to 3.02 not successful. Cannot obtain DFU Windows does not recognize driver - error. Updated Zadig to 2.6 Loaded drivers shown but windows wont accept any of them same error message. Would a Mac computer work better First of all thank you for time. I found the R/C impulse driver fixer. DFU came up. Started all over again using Spychalski instructions and all is working. no arming errors |
same arm | Eyes.fpv | 1 | 98 | 06-May-2024, 08:49 PM Last Post: SeismicCWave | |
INAV Sensors Barometer | GiantsFan5 | 1 | 126 | 02-May-2024, 05:46 PM Last Post: PeladoMat | |
INAV Angle mode problems | RConcienne | 1 | 148 | 18-Apr-2024, 04:17 PM Last Post: segler999 | |
Boxer SA Switch will NOT Arm my Quads | soky157 | 35 | 1,250 | 01-Mar-2024, 12:29 PM Last Post: SnowLeopardFPV | |
iNav Install I Question.... | Coleon | 15 | 467 | 23-Feb-2024, 07:31 AM Last Post: fpvapnea |
