I enjoyed getting back into the 250 class so much with my Chameleon build that I decided to let go of my only other 3 inch to fund a backup 250 quad. I really appreciated the thought that went into the Chameleon frame and am generally a big fan of Armattan but I really wanted to try something different. I never really gave these bus style X frames much thought and certainly don't gravitate to removable arms. Until I started noticing how many pilots whose skills I really respect swear by the ImpulseRC Apex frame. Even still, I didn't think it was that good of a looking frame until a salesperson at a local drone shop showed me a completed build. I was impressed by how it looked. So I decided screw it and pulled the trigger ...
My biggest concerns:
For starters, a size comparison against the only other 250 class I have, the Chameleon. When I first saw this in the shop, what struck me was how small it looked. Technically it has a bigger MTM than the Chameleon at 225 vs 220. My sense is the thin racing arms is what gives it the illusion of being smaller. The Chameleon's arms look like they are on steroids in comparison ...
A frame characteristic that kinda rubbed me the wrong way was how the main stack mounting screws are covered by the arms. This means you need to assemble the stack before assembling the frame or secure the stack from the nut up top - assuming the screw won't turn along with the nut. I'm not sure I subscribe to this concept ...
With that said, I was impressed by the arms locking mechanism. These things aren't going anywhere ...
Dry fitting the stack shows there's decent room. I'm using a 4mm spacer under the FC and a 6mm spacer under the Byte Frost. But the astute among you will also notice how close those standoffs are to the ESC pads on the Kakaute F7. This would prove to be highly annoying later ...
And then the individual ESCs ... I went out of my way to find the thinnest I could find for this 6S platform and these Holybro ESCs still were wider than the arms. You really need to get it to 10mm wide. Spedix makes fancy thin 40A ESCs that are 9mm wide.
The camera cage is held in place by the orientation of the hex standoffs and pressure between the top and bottom plates. I generally frown upon this type of camera cage since those carbon fiber tabs can and will wear over time with every removal and replacement of the top plate. Also, securing the standoffs becomes an exercise in patience since they need to face a certain way to securely hold the camera side plates. Too much reliance on things that are iffy to secure the camera in my opinion.
Dry testing the electronics ... pro tip ... solder the BEC jumper *BEFORE* you put everything together lol wow that sucked.
Here you can see how the ESC pads on the Kakute are blocked by the standoffs - both front and back. And you cannot forego those front standoffs since they secure the camera. (You could probably get away without the rear blocking standoffs ... but that aint how the House of Ronin rolls yo lol.) The saving grace here is the holes to the openings of the camera plates which allowed me to thread the ESC wires through. But these I don't think are for ESC wires but rather for the USB port for KISS OSD or something rather.
More for my own benefit for future reference than anything else ... my wiring.
And now let's go through the layers. Here is the first layer. You can see how I really had to wind the ESC wires around those ill placed standoffs. I know most people swing the wires to the inside, but I do not want a nest of wires building up between the FC and Byte Frost since the VTX tends to get extremely hot and will lower its own power because of that heat.
There is a 20x20 rear stack area which I very much appreciate. I've taken to using that rear area on frames to house the Crossfire Nano and Matek 9v reg ...
While I appreciate the 30x30 form factor of the Byte Frost (particularly in comparison to DJI's odd Air Unit shape), it really is a cumbersome VTX to install with its overall footprint. In particular, the antenna connector which extends so far out the back.
I'm going to take a moment to rant a little bit about the choice of hardware. This frame uses a lot of countersunk screws. While I get why the main stack M3 screws are countersunk so the arms can press up against them, I don't get why the rear 20x20 screws need to be countersunk as well? The reason this annoys me is because I like using my own M2 and M3 button or socket head screws which I typically cut down to size. In addition to countersunk screws, there are top threaded socket heads, those black plastic coned doohickeys in the pic below ... this frame very much wants you to use their specialized hardware.
I thought I would have much more room than this both in the rear and in front but it actually ends up being a really tight space ...
I'm a bit surprised also that the top plate is not more GoPro accommodating. What with all the added plastic components, I would have thought they would provide some sort of plastic GoPro mount as well. I ended up having to print two separate pieces for my GoPro mount since the single piece designs were just asking too much from my aging Printrbot. So I printed a couch separate from a Session case.
I recycled a similar design I made for the Chameleon tail antenna mount for use on this Apex frame ...
Money shots incoming ...
All in all I do like this frame despite my gripes against it. I would recommend an Armattan (any of them honestly) frame over this any day. Those frames have so much thought put into them and they go out of their way to accommodate various styles of and platforms of builds. This Apex frame is very much designed for KISS platforms with 4-in-1 ESCs. I knew that very well going in but I didn't think it was *that* focused. Well it is LOL.
I did get a chance to fly it but it gets dark so early here, I literally could not see lol. I have some electronic issues to iron out - the Crossfire was not powering up unless I pushed on it lollll no bueno. Also I got lazy and copied the CLI diff from my Chameleon to this Apex and walked out the door lol. Hey I figured same FC, same motors (sorta), same amp ESCs ... no problemo, recycle the PIDs!! Not so much haha. It felt like it kept wanting to fly west and my rates feel handicapped. So I will need to revisit the tune for sure.
- Would there be room for a Byte Frost VTX.
- This frame was very much designed to accommodate a KISS platform.
- Thin racing arms don't leave much room for individual ESCs.
