Help with tx mode
I have a v949 drone with wltoys tx in mode 1 and I would like mode 2. Does any6knoe if it can be changed either internally or through its function switched? The top left button usually does change modes in this type of tx but on this particular one it cycles through throttle power ranges.
The board inside says mode 2 in one too corner and mode 1 in the other. The LCD screen says mode 1 as though it should. Be changeable.
  Help Lost signal and GPS mode failsafe ludal79 5 1,037 26-Dec-2019, 11:15 AM
Last Post: ludal79
  Computer doesn't recognize FC in Bootloader mode sushicanfly 2 893 16-Dec-2018, 10:58 PM
Last Post: voodoo614
  Multishot and Turtle Mode JPFlorida 1 1,440 22-Sep-2018, 07:40 PM
Last Post: cche
  Help Problem with Angle/Horizon mode in Betaflight thomasFPV 3 11,534 14-May-2016, 05:24 AM
Last Post: almadillo
  Help New betaflight 2Khz mode noise and vibration JoshSky 13 13,460 06-May-2016, 01:02 AM
Last Post: TiborB
