HELP! CROSSFIRE NEWBIE CONFUSED
(16-Sep-2023, 09:01 AM)PJKMBAKER Wrote: I believe the FC and esc stack are
I-flight blitz fc and esc stack
As that is what the builder told me.
Maybe you gurus can confirm that?
Yes, it's an iFlight BLITZ Mini F7 stack -> https://shop.iflight.com/BLITZ-Mini-F7-S...-1-Pro1671
Wow thats as much as I paid for the whole Rooster!
So I will need a pin out for the fc board to check where to solder the wire to Out4Tx on the sixty9
Ok great. My confusion! I thought I needed the wire from out4tx to FC in order to control vtx from the tx module. However if I don't need the wire then I will leave well alone.
#19
Here is a copy paste of the current cli
diff all
# Betaflight / STM32F7X2 (S7X2) 4.4.0 Feb 1 2023 / 23:20:45 (4605309d8) MSP API: 1.45
# config: YES
# start the command batch
batch start
defaults nosave
board_name IFLIGHT_BLITZ_F722
manufacturer_id IFRC
mcu_id 001700074232501020343639
signature
# name: Rooster
feature GPS
serial 0 2048 115200 57600 0 115200
serial 3 2 115200 57600 0 115200
serial 5 1024 115200 57600 0 115200
# beacon
beacon RX_LOST
beacon RX_SET
map TAER1234
aux 0 0 1 900 1300 0 0
aux 1 1 0 900 1250 0 0
aux 2 2 0 1300 1700 0 0
aux 3 46 4 1375 2100 0 0
aux 4 13 2 1750 2100 0 0
aux 5 35 3 1800 2100 0 0
# vtxtable
vtxtable bands 6
vtxtable channels 8
vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 0
vtxtable band 3 UNKNOWN U FACTORY 0 0 0 0 0 0 0 0
vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 0
vtxtable band 5 RACEBAND R FACTORY 0 0 5732 5769 5806 5843 0 0
vtxtable band 6 IMD6 I CUSTOM 5732 5765 5828 5840 5866 5740 0 0
vtxtable powerlevels 1
vtxtable powerlabels 25
# master
set gyro_lpf1_static_hz = 0
set gyro_lpf1_dyn_min_hz = 0
set acc_calibration = 28,-23,10,1
set baro_hardware = NONE
set serialrx_provider = CRSF
set dshot_bidir = ON
set failsafe_procedure = GPS-RESCUE
set vbat_max_cell_voltage = 425
set ibata_scale = 207
set small_angle = 180
set gps_sbas_mode = EGNOS
set gps_ublox_use_galileo = ON
set osd_units = IMPERIAL
set osd_vbat_pos = 2433
set osd_rssi_pos = 2233
set osd_link_quality_pos = 2295
set osd_rssi_dbm_pos = 2360
set osd_tim_2_pos = 2455
set osd_craft_name_pos = 269
set osd_gps_speed_pos = 2209
set osd_gps_lon_pos = 18465
set osd_gps_lat_pos = 18484
set osd_gps_sats_pos = 2167
set osd_home_dir_pos = 2126
set osd_home_dist_pos = 2273
set osd_flight_dist_pos = 2337
set osd_altitude_pos = 2145
set osd_warnings_pos = 14730
set osd_avg_cell_voltage_pos = 2401
set osd_core_temp_pos = 258
set osd_canvas_width = 30
set osd_canvas_height = 13
set craft_name = Rooster
# profile 0
set dterm_lpf1_dyn_min_hz = 0
set dterm_lpf1_static_hz = 0
set tpa_mode = PD
profile 1
profile 2
profile 3
# rateprofile 0
set roll_rc_rate = 8
set pitch_rc_rate = 8
set yaw_rc_rate = 8
rateprofile 1
rateprofile 2
rateprofile 3
# save configuration
save
# dump
# config: YES
batch start
# name: Rooster
# resources
resource BEEPER 1 C13
resource MOTOR 1 B01
resource MOTOR 2 B00
resource MOTOR 3 C08
resource MOTOR 4 C09
resource MOTOR 5 B06
resource MOTOR 6 B07
resource MOTOR 7 B10
resource MOTOR 8 B11
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 C10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 C11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 B08
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SCL 4 NONE
resource I2C_SDA 1 B09
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource I2C_SDA 4 NONE
resource LED 1 C15
resource LED 2 NONE
resource LED 3 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_SCK 4 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MISO 4 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource SPI_MOSI 4 NONE
resource ADC_BATT 1 C02
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 A15
resource OSD_CS 1 B12
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 B02
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer B10 AF1
# pin B10: TIM2 CH3 (AF1)
timer B11 AF1
# pin B11: TIM2 CH4 (AF1)
timer A03 AF2
# pin A03: TIM5 CH4 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MOSI 4 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_MISO 4 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_TX 4 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma SPI_RX 4 NONE
dma ADC 1 0
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B01 0
dma pin B00 0
dma pin C08 1
# pin C08: DMA2 Stream 4 Channel 7
dma pin C09 0
dma pin B06 0
dma pin B07 0
dma pin B10 0
dma pin B11 1
# pin B11: DMA1 Stream 6 Channel 3
dma pin A03 1
# pin A03: DMA1 Stream 3 Channel 6
dma pin A08 0
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature RX_SERIAL
feature GPS
feature TELEMETRY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
map TAER1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 6
vtxtable channels 8
vtxtable powervalues 0
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 3 a
rxfail 5 h
# master
set gyro_lpf1_type = PT1
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 500
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 3
set dyn_notch_q = 300
set dyn_notch_min_hz = 100
set dyn_notch_max_hz = 600
set gyro_lpf1_dyn_expo = 5
set acc_hardware = AUTO
set acc_lpf_hz = 25
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 1
set baro_i2c_address = 0
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rssi_smoothing = 125
set rc_smoothing = ON
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_inverted = OFF
set sbus_baud_fast = OFF
set serialrx_halfduplex = OFF
set adc_device = 1
set blackbox_disable_rc = OFF
set blackbox_mode = NORMAL
set blackbox_high_resolution = OFF
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 550
set dshot_burst = OFF
set dshot_edt = OFF
set dshot_bitbang = OFF
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 15
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set align_board_yaw = 0
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set mixer_type = LEGACY
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set imu_process_denom = 2
set gps_provider = UBLOX
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_ublox_mode = AIRBORNE
set gps_use_3d_speed = OFF
set gps_sbas_integrity = OFF
set gps_rescue_min_start_dist = 30
set gps_rescue_initial_climb = 10
set gps_rescue_return_alt = 30
set gps_rescue_ground_speed = 500
set gps_rescue_pitch_angle_max = 40
set gps_rescue_roll_mix = 150
set gps_rescue_descent_dist = 20
set gps_rescue_descend_rate = 100
set gps_rescue_landing_alt = 4
set gps_rescue_throttle_hover = 1275
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY
set gps_rescue_min_sats = 8
set gps_rescue_throttle_p = 15
set gps_rescue_throttle_i = 15
set gps_rescue_throttle_d = 15
set gps_rescue_velocity_p = 8
set gps_rescue_velocity_i = 30
set gps_rescue_velocity_d = 20
set gps_rescue_yaw_p = 20
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 1
set tlm_inverted = OFF
set tlm_halfduplex = ON
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set ledstrip_brightness = 100
set osd_warn_bitmask = 8191
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = -60
set osd_rsnr_alarm = 4
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = 0
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_rsnr_pos = 234
set osd_tim_1_pos = 234
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_wh_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_pilot_name_pos = 234
set osd_compass_bar_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_ready_mode_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_log_status_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_aux_pos = 234
set osd_sys_goggle_voltage_pos = 234
set osd_sys_vtx_voltage_pos = 234
set osd_sys_bitrate_pos = 234
set osd_sys_delay_pos = 234
set osd_sys_distance_pos = 234
set osd_sys_lq_pos = 234
set osd_sys_goggle_dvr_pos = 234
set osd_sys_vtx_dvr_pos = 234
set osd_sys_warnings_pos = 234
set osd_sys_vtx_temp_pos = 234
set osd_sys_fan_speed_pos = 234
set osd_stat_bitmask = 14124
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_framerate_hz = 12
set osd_aux_channel = 1
set osd_aux_scale = 200
set osd_aux_symbol = 65
set osd_craftname_msgs = OFF
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_softserial_alt = OFF
set vtx_freq = 0
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = NOMINAL
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set led_inversion = 0
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set scheduler_relax_rx = 25
set scheduler_relax_osd = 25
set serialmsp_halfduplex = OFF
set rpm_filter_harmonics = 3
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_lpf_hz = 150
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set pilot_name = -
set altitude_source = DEFAULT
set altitude_prefer_baro = 100
set altitude_lpf = 300
set altitude_d_lpf = 100
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
# profile 0
set profile_name = -
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_type = PT1
set dterm_lpf2_type = PT1
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation = 0
set pid_at_min_throttle = ON
set anti_gravity_gain = 80
set anti_gravity_cutoff_hz = 5
set anti_gravity_p_gain = 100
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 15
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 100
set throttle_boost = 5
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 30
set d_min_pitch = 34
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 0
set feedforward_boost = 15
set dyn_idle_min_rpm = 0
set dyn_idle_p_gain = 50
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set level_race_mode = OFF
set simplified_i_gain = 100
set simplified_d_gain = 100
set simplified_pi_gain = 100
set tpa_mode = PD
set tpa_rate = 65
set tpa_breakpoint = 1350
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set yaw_rc_rate = 8
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set pitch_srate = 67
set yaw_srate = 67
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
# end the command batch
batch end
#20
Not sure if I have a bind yet. I just aboout managed to hold the microscopic bind button whilst powering up the drone, with the XFire micro tx module in the zorro set to bind through TBS Agent Lite. The little led on the sixty9 rx board is solid blue and the leds on the iflight fc stack sre solid red flashing blue. Is that a bind? Not sure as in betaflight the rx channels arent moving. I will try and send a picture
#21
The LED status for the Crossfire receiver is either green or red, so that blue LED must be related to the VTX channel on the Sixty9 and nothing to do with the Crossfire receiver part it. The LEDs on the flight controller have nothing to do with the binding status of the receiver so just ignore those.
You don't need to hold the bind button down while powering it the Sixty9. You power it up first and then press the bind button which means you don't need more than 2 hands Smile
This is the binding procedure when doing a manual bind using the button:
  1. Power down the Sixty9
  2. Put the Crossfire module on your Zorro into binding mode
  3. Power up the Sixty9
  4. Push the Bind button on the Sixty9
Both the receiver link status LED on the Sixty9 and the LED ring on the Crossfire module should then turn solid green to indicate a successful bind.
#22
Got it. Thanks for sorting that out. I now have a bind and can control vtx from my tx. Hooray!
Now rebuilding the drone and checking betaflight for channels and modes etc
Thanks for the help.
#23
Any idea which caddx camera this is on my Antarran Rooster?
[Image: MsCGVoql.jpg]
[Image: I0F0cgfl.jpg]
[Image: Uz7wN2Hl.jpg]
I have a spare green and black wire coming from it ending in a tiny just plug. Is it to connect a second action camera?
#24
That looks like a Caddx Ratel to me, but, I could be wrong.
The black and green wire are to attach a “joystick” to change the camera’s osd options and settings (this is different than betaflight’s osd):
https://caddxfpv.com/products/osd-menu-board
Dangerous operations.
#25
Based on the lens, it also looks to me like the Starlight version of the Caddx Ratel rather than just the standard version.
  • Lemonyleprosy
#26
Aaargh! I had most things working in modes. But I wanted to use aux 4 for GPS return. The switch on the tx was operating the Chanel ok but the mode wasn't enabling even though the range was set correctly. Then I noticed a message in bf that to use GPS I had to enable a serial port. So I went into ports and noticed that uart4 was linked to GPS but appeared to be disabled so I enabled it and did save/reboot. Then all horribly wrong. Now ports are all cleared except for uart1. The link to TBS has gone as has GPS. Now the receiver bands don't respond to the tx. Tried rebooting the FC and TBS sixty9 Rx but no good. Any ideas? Can I get my port settings back from my original cli file?
#27
Yes, you can just run the CLI file back in.
Once you've configured a load of things and got them working, always get into the habit of taking a new CLI dump all and diff all as a backup. You can never have too many backups.
  • Lemonyleprosy
#28
Well I loaded in my backup cli file from before making changes (see post of cli dump from 9 hours ago)
When I go into ports in BF they are all blank.
What to do to reset those to the correct values ? Are they listed in my cli file?
#29
I tried just copying and pasting into cli the lines starting #serial that seemed to put the ports back the way they were originally but depite having a bind between my micro tx module and the sixty9 rx, the channel bands are not moving in BF Receiver tab. So now Im stuck.
Is there a way to start reconfiguring from scratch as if this was a newly built drone?
#30
To restore everything, just copy/paste the whole CLI dump into the CLI textbox and then press <ENTER>. Then type save and press <ENTER> again.
If you want to reset everything back to the default FC values, just type defaults and press <ENTER>.
  Help Crossfire Nano RX bound to Tango II but no sticks/switches input in BF nor IRL illumn` 4 254 31-May-2024, 10:23 PM
Last Post: illumn`
  Announcement TBS Crossfire / Tracer 6.36 Firmware Released SnowLeopardFPV 85 44,253 23-May-2024, 02:18 PM
  Thinking of ELRS over Crossfire Rob Axel 20 2,430 09-May-2024, 01:04 AM
  Switching to FC expresslrs or crossfire transmitters zomer 1 159 01-May-2024, 07:54 PM
Last Post: matt0725
  Crossfire nano rx and tx no binding cele_FPV 3 202 31-Mar-2024, 05:27 PM
