  • 1 Vote(s) - 5 Average
GEPRC Phantom / GEPRC SMART25
EDIT: GEPRC have renamed the original Phantom as the SMART25 to align with their other "SMART" lines of quads.
I've been meaning to build a micro/toothpick type quad for a while but seeing as I haven't even been able to get my arse into gear and finish the outstanding repairs on my Trashcan, or actually finish building the Acrobrat that I bought all the parts for almost 9 months ago, I decided to just buy an already built BNF micro quad in the Banggood 13th anniversary sale.
Off the back of AndyRC's trusted review, the GEPRC Phantom is the one I decided to pull the trigger on over all of the others (HERE). I got the one with the XM+ receiver included so I can just bind it and go without to much messing around (although I'll first need to flash EU-LBT firmware to it so it matched my X9D+). It's not the fastest of the toothpick style quads but I like the fact that it uses a 16x16 stack instead of an AIO whoop style FC, and I like that it uses a proper carbon fibre centre body construction. It sort of reminds me of a baby version of my Martian II Smile
The one thing I will be changing almost immediately tnough is the Caddx EOS2 camera though because it's quite a poor camera with it's over-saturation of the red spectrum, so I've pushed the boat out and also ordered a RunCam Racer Nano for it. I'm probably also going to stick on an omni-directional VTX antenna for better range.
I love flying my 5" but I'm really looking forward to trying out these toothpick style quads. If I'm lucky I may even get to fly it in the park that I used to fly my 5" at before I got ousted as a nuisance and noise polluter. I guess we shall see.
I know that Oscar has done a review on the Phantom (HERE), but below is AndyRC's glowing review for anyone interested. I'll let you know what I think of it once I've had a chance to fly it. It should be with me in a couple of weeks.
The GEPRC Phantom is supplied from the factory with Betaflight 3.5.7 installed. Below is a CLI "diff" of the original untouched GEPRC Phantom configuration as it was supplied with from the factory...
# Betaflight / MATEKF411 (MK41) 3.5.7 Mar 15 2019 / 22:05:14 (e9130527c) MSP API: 1.40
board_name MATEKF411
manufacturer_id
# name
name PHANTOM
feature LED_STRIP
feature AIRMODE
# beacon
beacon RX_LOST
beacon RX_SET
serial 0 8192 115200 57600 0 115200
led 0 6,13::CTOBVIW:0
led 1 7,13::CTOBVIW:0
led 2 8,13::CTOBVIW:0
led 3 9,13::CTOBVIW:0
aux 0 0 0 900 1275 0 0
aux 1 1 1 1300 1700 0 0
aux 2 2 1 1700 2100 0 0
aux 3 13 2 900 1275 0 0
# master
set acc_calibration = -31,90,-385
set baro_hardware = NONE
set align_board_yaw = 90
set ibata_scale = 210
set small_angle = 180
set pid_process_denom = 1
set osd_vbat_pos = 2497
set osd_tim_1_pos = 273
set osd_tim_2_pos = 2519
set osd_vtx_channel_pos = 2487
set osd_current_pos = 2464
set osd_mah_drawn_pos = 2507
set osd_craft_name_pos = 2475
set osd_warnings_pos = 2441
set vtx_channel = 2
set vtx_power = 3
set vtx_freq = 5760
set vcd_video_system = PAL
# profile
set dterm_notch_cutoff = 0
set feedforward_transition = 50
set p_yaw = 55
# rateprofile
And this is a complete CLI "dump" of the same:-
manufacturer_id
# name
name PHANTOM
# resources
resource BEEPER 1 B02
resource MOTOR 1 B04
resource MOTOR 2 B05
resource MOTOR 3 B06
resource MOTOR 4 B07
resource MOTOR 5 B03
resource MOTOR 6 B10
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A03
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 NONE
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 NONE
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 B08
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 B09
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 C13
resource LED 2 C14
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 NONE
resource ESCSERIAL 1 NONE
resource ADC_BATT 1 B00
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 B01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource OSD_CS 1 B12
resource SPI_PREINIT_IPU 1 A04
resource SPI_PREINIT_IPU 2 B12
resource SPI_PREINIT_IPU 3 NONE
resource SPI_PREINIT_IPU 4 NONE
resource SPI_PREINIT_IPU 5 NONE
resource SPI_PREINIT_IPU 6 NONE
resource SPI_PREINIT_IPU 7 NONE
resource SPI_PREINIT_IPU 8 NONE
resource SPI_PREINIT_IPU 9 NONE
resource SPI_PREINIT_IPU 10 NONE
resource SPI_PREINIT_IPU 11 NONE
resource SPI_PREINIT_OPU 1 NONE
resource SPI_PREINIT_OPU 2 NONE
# mixer
mixer QUADX
servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature LED_STRIP
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSED
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
# map
map AETR1234
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtx
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set align_gyro = DEFAULT
set gyro_32khz_hardware_lpf = NORMAL
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 100
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 300
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = ON
set yaw_spin_threshold = 1950
set gyro_use_32khz = OFF
set dyn_notch_quality = 70
set dyn_notch_width_percent = 50
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 1
set baro_i2c_address = 0
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set baro_cf_alt = 965
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_type = INTERPOLATION
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = SBUS
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set airmode_start_throttle_percent = 32
set serialrx_halfduplex = OFF
set adc_device = 1
set blackbox_p_ratio = 32
set blackbox_device = SERIAL
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 450
set dshot_burst = OFF
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_full_cell_voltage = 41
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set vbat_detect_cell_voltage = 30
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_throttle_min = 1200
set gps_rescue_min_sats = 8
set deadband = 0
set yaw_deadband = 0
set runaway_takeoff_deactivate_throttle_percent = 25
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set smartport_use_extra_sensors = OFF
set ledstrip_grb_rgb = GRB
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_rssi_pos = 234
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_core_temp_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_battery = OFF
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set vtx_band = 4
set vtx_channel = 2
set vtx_power = 3
set vtx_freq = 5760
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set led_inversion = 0
set dashboard_i2c_bus = 1
set dashboard_i2c_addr = 60
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
# profile
set dterm_lowpass_type = PT1
set dterm_lowpass_hz = 100
set dterm_lowpass2_hz = 200
set dterm_notch_hz = 0
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_gain = 5000
set acc_limit_yaw = 100
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = ON
set smart_feedforward = OFF
set iterm_relax = OFF
set iterm_relax_type = GYRO
set iterm_relax_cutoff = 11
set iterm_windup = 40
set iterm_limit = 150
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 50
set i_pitch = 50
set d_pitch = 27
set f_pitch = 60
set p_roll = 46
set i_roll = 45
set d_roll = 25
set f_roll = 60
set p_yaw = 55
set i_yaw = 45
set d_yaw = 0
set f_yaw = 60
set p_level = 50
set i_level = 50
set d_level = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
# rateprofile
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
set throttle_limit_type = OFF
[-] The following 3 users Like SnowLeopardFPV's post:
  • _Eend_, peri, L0stB1t
I'm really interested in hearing what you think about this once you get some packs in on it.  I haven't flown in a while and have been spending some time on the Sims to get my flying chops back up to snuff.
A slower toothpick in an open space is probably the way for me to go for a bit........  Big Grin
The fact that there's a highway to hell and only a stairway to heaven says a lot about the anticipated traffic numbers......
Honestly i'd choose the Sailfly over this one for value and top speed Smile
I've been eyeballing the HM Larva X.
Have either of you had a chance to fly it?
HappyModel are still using the Crazybee F4 AIO boards in their models which is a bad move IMO and I've already experienced the voltage regulator failure they are susceptible to with my Trashcan. I think they may have partly resolved the issue with the release of the V3 boards but the Sailfly-X still seems to come with the V2.x board for whatever reason. Albert Kim also complained that the Sailfly has durability issues with both the frame and the motors which are apparently a common failure point. I guess it depends how you fly it and where. So I decided to steer clear of the Sailfly for all of the aforementioned reasons. I don't really care for raw top speed as long as the speed is reasonable, and the 16x16 stacks seem to be a lot more reliable than the whoop style AIO boards.
The Larva-X also uses a Crazybee FC, although it is one of the V3 boards.
Maybe i am lucky getting the Sailfly late, and the capacitor fix is working well (or they did some change to the FC who knows), it's been very reliable for me over 50-60 flights and a few others i know.
Geprc phantom is the way to go.
Well it took a while to arrive but my GEPRC Phantom finally got delivered yesterday. Before I take it on a maiden, I need to flash the XM+ receiver with EU-LBT RSSI firmware and I also need to fit a buzzer, because if I don't then it will be just my luck that I end up losing it in some undergrowth on it's first outing. It did come with ESC buzzers enabled but those are pretty useless in my experience so it will be getting a proper buzzer. I did think about putting a Crossfire Nano receiver in it but I think I'll just stick with the XM+ for now and see how it goes.
Interestingly it has Betaflight 3.5.7 loaded onto it, so I guess they were may have been able to better tune that version on such a tiny quad than Betaflight 4.x.
[Image: 3WZnStL.jpg] [Image: Q0zJyzM.jpg] [Image: 20MGVg6.jpg] [Image: u7clBuP.jpg] [Image: lBUys7j.jpg] [Image: UCL700w.jpg] [Image: MVKDBoB.jpg] [Image: 0qLAUBQ.jpg] [Image: l8b6K17.jpg] [Image: DvHYHQC.jpg] [Image: cAQQRCz.jpg]
Even from pictures and videos online, you don't realise how tiny these toothpicks are until you actually hold one in your hand.
[Image: ddqoPwz.jpg]
And a size comparison with my 5" Martian II. The Phantom almost looks like a baby Martian Big Grin
[Image: i4xtc7Z.jpg]
[-] The following 9 users Like SnowLeopardFPV's post:
  • hawk01, rjalex, Droneranger, unseen, L0stB1t, Krohsis, hugnosed_bat, Scott_M, sloscotty
Great to see you have now got a toothpick style quad now snow.  I have found the sheer accessibility to fly with a toothpick - easy on the ears, public and dogs - gave me more time to practice than having the 5 inch tear up the skies and can be heard miles away.
Early BF 4.x versions are horrible for this class of quad, you really need to turn down the PIDs by at least 30% of their stock values before you can even think about flying it.   The power to weight in this class is very high and BF 4.x  (early BF4 at the very least) just created pocket rockets that would take off to the moon when armed.   I use 3.5.7 on all my small class quads and out of the box on stock PIDS they are way more stable.  Things may of changed with the latest version of BF 4.1.
It pays to check out the GitHub docs on BF4.x if you're going to flash it with that.  Although I'm pretty sure you already know this. Big Grin
I have found that turning up the beacon and motor sounds values in BLHELI_S configurator makes for some loud, chirpy motors, this helps when space is at a premium and one doesn't have a buzzer installed.
cheers,
ph2t.
(05-Oct-2019, 04:45 AM)ph2t Wrote: Great to see you have now got a toothpick style quad now snow.  I have found the sheer accessibility to fly with a toothpick - easy on the ears, public and dogs - gave me more time to practice than having the 5 inch tear up the skies and can be heard miles away.
Yes, I'm going to try and take this little thing back to the park that I and my 5" got kicked from and see if any dog walkers start trying to kick up a fuss about it. While I love the "baby Alien" style of the frame, the downside is that it does have some angular edges so it doesn't look quite as soft and harmless as some of the other toothpicks with their flexible TPU canopies. I'll guess I'll find out what reception it gets if the weather ever stops being so miserable.
The Phantom was released after Betaflight 4.x was officially released so there must be a reason that GEPRC didn't opt to use Betaflight 4.x for it. It's probably as you said, that BF 3.5.7 is just kinder for these small class quads. I never really dabbled in the tuning aspects of Betaflight and have been spoiled in that on my 5", the stock out-of-the-box tuning just seems to work fine for my mediocre piloting skills so I've never needed to mess around with any PID settings. I'm therefore just going to leave the Phantom on Betaflight 3.5.7 and hope that the factory tuning that GEPRC already did will work fine without me needing to change anything. If I was to move to BF 4.x then I would most likely have to start trying to change all the PIDs which I don't really want to get into unless I have to. I guess I'll just have to try and try and get over my OCD that this quad isn't on the latest greatest version of Betaflight Big Grin
I have the real estate in this frame to fit a buzzer which is one of the advantages of this style of frame so I'm happy to sacrifice a few extra grams of weight for the sake of a proper buzzer that you can hear a mile off.
  • hugnosed_bat
A FullSpeed Lucky Box Buzzer is now all fitted to my Phantom and is working a treat. I could have probably just used a regular buzzer, but this is the smallest self-powered buzzer on the market and only weighs in at just over 2 grams so I decided that small weight gain was acceptable. It fits perfectly between the camera and the stack, stuck down with double sided sticky foam tape and then strapped down securely with two cable ties. In this location there is even easy access to get to the button on it with your finger. It's a 90dB buzzer so way louder than the beeping ESCs. Now I will feel safe actually flying this tiny thing out some distance from me knowing that I'll have a much better chance of finding it if it comes down Big Grin
The 16x16 stack is very nice and looks really well engineered with header pins running through the stack to connect each individual board together, so no hard soldered wires or wiring harnesses to contend with. And if anything breaks I can just replace the one affected board rather than the whole lot, so I'm glad they used a proper stack in this instead of one of those AIO boards.
[Image: CrrDAsA.jpg] [Image: U8bhfrd.jpg] [Image: OZIdRTz.jpg] [Image: HhWQdfl.jpg] [Image: SS1eDId.jpg] [Image: YLPlgfd.jpg] [Image: 6Mr8oKi.jpg] [Image: 4Hol3fG.jpg] [Image: lBmhwpZ.jpg] [Image: TxLzuxM.jpg] [Image: 86aNPP4.jpg] [Image: XeoOehD.jpg]
While I had the lid off I also flashed the XM+ with EU-LBT firmware which also broadcasts RSSI on channel 16. I was hoping to be able to do that with it still wired in by just attaching test clips to the exposed wires where they are soldered to the FC but unfortunately that turned out to be a fail because the 5V power from the Taranis fired up the 5V circuit on the FC resulting in a failed flash because the FC would have been trying to communicate with the XM+ over the white SBUS wire at the same time as the Taranis trying to flash data to it. So I had to temporarily desolder the red wire going from the XM+ to the FC. Then the firmware flashed successfully. A bit of a PITA but the XM+ hasn't had a new ACCST firmware update since 2017 so I don't think there are going to be any more updates to be applied any time soon (or ever).
Now all bound to my transmitter and appears to be working just fine from a control and auxiliary channel point of view. I've not been able to check the RSSI yet but hopefully it's all working. I guess I'll find out soon enough.
[Image: WLBcO0K.jpg]
[-] The following 5 users Like SnowLeopardFPV's post:
  • Droneranger, iFly4rotors, Scott_M, Krohsis, hugnosed_bat
Your photos look like a product catalogueSmile
The stack is an awesome piece of kit and responsible for most of the $ figure the bnf attracts. I’m using it in my inv8r build and have found the shear lack of soldering required quite refreshing.
My only concern in the uf.l antenna connector. I’ve put s small glob of hot glue over mine and a small amount of the surrounding pcb just to keep it secure a bit more.
Happy flying mate!
ph2t.
[-] The following 1 user Likes ph2t's post:
  • hugnosed_bat
Some more catalogue pictures below Big Grin
The Foxeer Lollipop VTX antenna arrived so it is now fitted in place of the original dipole for a better video signal. Spare props also arrived so I they have now added some colour and a bit of a personal touch Smile I also replaced the crappy nylon straps it came supplied with for some proper rubber coated straps.
The FullSpeed Buzzer, Foxeer Lolipop, and Straps added an extra 7 grams in weight on top of the factory build.
I'm also getting a nice clean picture through the goggles on the bench. Because the Caddx Turbo EOS2 cameras can be a bit hit and miss for picture quality, I actually bought a RunCam Racer Nano to replace the stock EOS2 camera with, but the picture I'm seeing though the goggles looks pretty good so I think I'll stick with the EOS2 camera for now and see how it performs out in the field. It it's acceptable then I'll just keep the RunCam Racer Nano for a different build.
I wanted to do a maiden flight this weekend but it was raining on Saturday and today was just way too windy. I know my 5" would have been able to handle the wind but I'm unsure about this little thing, so I need to take it out on a calm day first to get used to its capabilities. Hopefully the weather will be a bit kinder next weekend Smile
New Lollipop VTX antenna, coloured props, and straps fitted...
[Image: hwTQZUr.jpg] [Image: xJjY5hG.jpg] [Image: sDVbQh5.jpg] [Image: 2gFZj24.jpg] [Image: uX4egPb.jpg] [Image: kB1m9wq.jpg]
And with a Tattu 75C 450mAh 2S LiPo attached...
[Image: 52UAPpg.jpg] [Image: 48sDA3o.jpg] [Image: MlGdo6a.jpg] [Image: HKKTwK2.jpg]
Weight without a LiPo attached is 66 grams (0.15 lbs), and AUW with LiPo attached is 95 grams (0.21 lbs). It's not particularly light by toothpick standards but I think (hope) it will still handle OK.
[Image: nhmGnUX.jpg] [Image: yWdxYtT.jpg]
  • iFly4rotors, Scott_M, Krohsis, sloscotty, hugnosed_bat
try the hq2535 would be my recommandation x-)
little beauty - nice white wires...
#15
(07-Oct-2019, 06:21 AM)hugnosed_bat Wrote: try the hq2535 would be my recommandation x-)
Yeah, I wasn't sure about using tri-blade props so I just stuck with the bi-blades for now. The ESCs are rated at 12A continuous current, so I'll see what sort of current they draw at thrust and then make a decision whether or not to risk sticking on some tri-blades Smile
I'm itching to get this thing in the air Big Grin
  Build GEPRC SMART Walksnail 2.5 Inch Toothpick build Cyberess 28 909 26-Mar-2024, 10:21 AM
Question Anyone got a GepRC Darkstar 20? Backup Cli? alvestadkristian 3 241 11-Feb-2024, 09:49 PM
  GEPRC TinyGo for a first FPV quad? Scro 5 509 19-Dec-2023, 11:59 PM
Last Post: mstc
  Help GEPRC TinyGO 4K FPV Whoop RTF Controller issue aiflai 14 6,501 10-Dec-2023, 05:48 AM
Last Post: LEM17
  Build GEPRC Phantom Rebuild brettbrandon 27 1,619 26-Nov-2023, 01:09 PM
Last Post: iFly4rotors
