06-Feb-2023, 12:49 AM
I recently crashed my Tinygo 4k and the battery connector broke. So I replaced it. Now the it won’t power up with batteries just through the USB.
GEP RC Tinygo only power through USB not battery |
06-Feb-2023, 12:49 AM I recently crashed my Tinygo 4k and the battery connector broke. So I replaced it. Now the it won’t power up with batteries just through the USB. 06-Feb-2023, 12:54 AM (This post was last modified: 06-Feb-2023, 03:26 AM by Lemonyleprosy.) First thing to do is take a close look the board- use a magnifying glass to make sure that there aren’t any solder balls or solder blobs. Take a good look at where you replaced the battery cable and make sure nothing is bridged. Can you post clear, up close photos of where you soldered the battery connector? Edit: also, if you’ve got a multimeter, put it in continuity mode and make sure it doesn’t beep when you touch probes to the main positive and negative battery cable pads. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. |
Help Beta85x HD with 2s Battery | nicoinco | 5 | 576 | Yesterday, 09:33 PM Last Post: Arango | |
Help Tinyhawk 3 Plus Freestyle - battery ph2 to bt2? | CDCMeteor75ProNewb | 5 | 246 | 22-Apr-2024, 09:31 PM Last Post: Timmyhawk 2 | |
GEPRC TinyGo for a first FPV quad? | Scro | 5 | 550 | 19-Dec-2023, 11:59 PM Last Post: mstc | |
Help GEPRC TinyGO 4K FPV Whoop RTF Controller issue | aiflai | 14 | 6,567 | 10-Dec-2023, 05:48 AM Last Post: LEM17 | |
1S Battery Settings in OSD | segler999 | 7 | 944 | 23-Nov-2023, 01:34 AM Last Post: segler999 |
