Recently I've been messing around with eCalc (https://www.ecalc.ch/xcoptercalc.php) to check some build ideas. I didn't know where to post this, but since my primary goal is to optimize efficiency I figured I'd post it here.
I first ran some calculations using my Cinerat, which I was trying to convert to a LR quad. Putting in the specs as-is, I get the following result which seems reasonable given my experience:
I know this looks complicated at first, so I'll walk through it to the best of my understanding. Please let me know if you spot any mistakes!
1. First you specify the model weight. You can either specify the AUW, the weight without battery, or the weight without the entire drive system (motors, props, ESCs, battery). For my purposes, I specify the weight w/o battery so I can play around with various battery options (ie LiPo vs LiIon) and it will update the AUW automatically. Note that if you specify the weight without drive, the way it calculates the AUW is a little unintuitive. For a quad it's: 4 x motor weight + 4 x ESC weight (it assumes individual ESCs) + battery weight x cells (again, it assumes you're entering the weight of an individual cell, not the whole pack), and then it adds 10% on top of this for things like props. For a LR build, this is likely way too high, so I prefer either specifying the AUW or the dry weight for better accuracy.
2. The frame size is only taken into account to make sure your propellers won't hit each other and in the drag calculation later on for range estimation.
3. Next you enter the battery specs. Here I'm using my GNB 6s 1100mAh pack. Note that the weight is per cell, so for a 6s pack you divide the total weight by 6. It has a drop down selection for a range of generic batteries and Li-Ion cells. Again, for a LR build you'll probably be using LiPo's that are much lighter than the defaults here, but having the quick Li-Ion selections are handy.
4. Here you specify the ESC parameters. Note that it assumes individual ESCs, so take that into account if you're using a 4 in 1. I just make sure the current limits are correct, and set the weight equal to my stack weight / 4.
5. Even though the other presets seem quite out of date, the motor drop down contains a lot of the newer efficient motors you'd use in a LR build. You can also define a custom motor if you have the specs. I couldn't find the specs for the Ethix Flat Rats on my Cinerat, so I'm using the closest I can find which are the GEPRC 1507 2800kv.
6. Here you define the prop. Most manufacturers are represented in the presets, and they change the properties of the props slightly (I assume due to different airfoils/blade shapes/thicknesses etc). For example, the Gemfan props seem to be slightly more efficient than the HQ props but produce slightly less thrust.
7. Here you can define the weight and current draw of any other accessories on your build. I've entered the approximate amp draw of the Caddx Vista, but since the weight is already accounted for in the dry weight I left that at zero.
Then you hit calculate and the magic happens. It will give you estimated current draws at max power, max efficiency, and hover, along with things like estimate range, rate of climb, thrust to weight ratio, throttle at hover, etc. It will also graph range vs speed estimates and motor characteristics at full throttle.
Results
For my Cinerat, it predicts a mixed flight time of 4.1 mins and a hover time of 7.9 mins. My flight times were just a touch over 6 mins with some easy cruising, so this is in line with reality. I also have some 3x4x3 props so I reran the calculations for those as well, along with seeing how removing the prop guards would affect things.
Configuration - Mixed Flight Time - Hover Time - Power:Weight - Specific Thrust (at hover)
3x3x3 with prop guards - 4.1 mins - 7.9 mins - 3.8:1 - 2.88 g/W
3x4x3 with prop guards - 3.9 mins - 8.1 mins - 4.3:1 - 2.96 g/W
3x3x3 w/o prop guards - 4.4 mins - 9.3 mins - 4.3:1 - 3.03 g/W
3x4x3 w/o prop guards - 4.2 mins - 9.5 mins - 4.8:1 - 3.11 g/W
So the higher pitch props produce more thrust and allow you to hover at a lower throttle setting, but are less efficient and result in a slightly reduced mixed flight time.
Next, I wanted to see if my idea of dropping the prop guards and using a 4s 3000mAh Li-Ion pack would give me the flight times I was looking for. Short answer: No. The 1507 2800kv motors produce plenty of thrust but are not particularly efficient, especially when restricted to 3" props by the frame. I'll post up that analysis in a bit, along with an analysis of some of the LR 4" builds posted here to see how accurate eCalc is when it comes to max efficiency builds. After that, I'll post my theoretical calculations for a ~100g dry weight 2.5" build with a DJI digital system and a predicted flight time of 20 mins!
Results
