FrSky X-Lite S Settings for my Whoop 65 Pro 2
So, with all the trouble I have been having with my Whoop I took the advice to create a new model on my transmitter and am stuck on the first screen. I have to choose between Plane, Delta, and Multi. I tried making a model with each selection but they each asked questions to setup different things I was not sure which I should go with.
Thanks again,
Don
Select multi and just go with all the default channel selections for the sticks.
OK, Will do, Thanks for all your help
  3D Print Tiny Whoop Gate KENN 2 102 20-Jun-2024, 01:01 AM
Last Post: KENN
  Build 35mm CF frame pusher whoop ph2t 8 245 19-Jun-2024, 10:02 PM
Last Post: drumgod
  Help Meteor 75 Pro Core Temp sasquatch 7 274 13-Jun-2024, 03:05 AM
Last Post: sasquatch
  Meteor 75 pro no green rx led arju 1 113 07-Jun-2024, 04:01 PM
  Build Pavo Pico WS Lite mstc 20 2,458 16-May-2024, 12:48 AM
Last Post: mstc
