08-Jun-2021, 08:38 PM
Evening;
looking for some assistance.
Radio: FrSky Taranis Q7 [Access]
Receiver: FrSky M+
Fc: Mamba 722
Desired end state - run F.port from the M+ to the FC.
1. I've updated my tx firmware to this [2021-02-03 ISRM v2.1.6]
2. I've updated the Rx firmware to this: [Archer-X_2.1.7.frsk] - this would not update via OTA - when attempting to do this by OTA the system hung at 'waiting for RX' [despite cycling the RC power] - the FW was updated by s.port plugged into the radio and indicated successful.
3. The receiver is bound to the transmitter - however when I select the receiver and 'options' within the tx setup page - it hangs at 'waiting for RX'
I have had the 'waiting for RX' issue on a previous build and instead opted for an SBUS connection but I would like to understand what I'm doing wrong here.
I think i need to select F.Port under options to enable this (hence why the below set up in betaflight isn't working (?) )
the UART for S.Port / F.Port on the Mamba 722 seems to be UART 5.
In beta flight I have set UART 5 to "serial RX" and in the config tab I've set up "serial receiver" and FRSKY, F.Port as the options.
Any thoughts or experience with this would be appreciated.
cheers.
Receiver: FrSky M+
Fc: Mamba 722
cheers.
