07-Oct-2017, 07:02 PM
Hello,
I just finished building my new drone.
My specs:
TS5828S 5.8Ghz 40CH 600mW FPV AV Wireless Transmitter,
FPV 5.8G Pilz Antenne High Gain RHCP VTX / VRX Clover,
Foxeer Monster V2 16:9 1200TVL OSD Audio Widescreen FPV Cam,
FrSky XM+,
Betaflight OmniBus F4 V3 Flight Control Built-in OSD/BEC,
20A Lipo Mini 20A 2-4S ESC Speed Control Little Bee,
Matek Systems PDB XT60 W/ BEC 5V & 12V 2oz Copper
Everything works except two things.
First: My max FPV signal range is 40 meters(~100 feet). I had the same tx on my previous drone, and I got over 1km(~3280 feet) FPV sinal range. So my first thought was: I must have fried my tx. So I bought a new one, same problem. I changed and resoldered the cables, same problem. Tried all channels, same problem. I used the tx on my friends drone, works for him. I messured how much voltage output the tx gets, in case if it would be too low. Its 12V like it should be.
Second: Today I tried to fly again then my xm+ lost signal. The LED is green so it has connection to the terranis, but the RSSI/Fly modes dont update in the osd and the drone doesnt accept any input from my terranis. I also updated the firmware, same problem.
Can anyone help?
My specs:
FrSky XM+,
Can anyone help?
