Threads: 19
Likes Received: 9 in 7 posts
Likes Given: 17
0 Hey guys,
Brand new flight controller. When powering the 6s battery it is only showing 2cells connected through beta and beta osd..volatge is wayyy off saying 1.4 volts.. what could be the cause?
Threads: 125
Likes Given: 99
388 How are you wiring the FC and ESCs? Is it 4in1 ESC port into the FC port for connecting the two?
Threads: 19
Likes Given: 17
0 Ive got a matek fhub 6s pdb, powering the seperate gs35a spedix escs in which the esc signal wires are soldered directly on the fc solder pads on the botton side of the board.
Threads: 595
Likes Received: 9,039 in 6,690 posts
Likes Given: 1,428
796 How have you wired the FC to the PDB? The FC will need VBAT (VCC) voltage connected to it in order to read LiPo voltage and not just a 5V power feed from the PDB. Have you actually done that?
Threads: 125
Likes Given: 99
388 Can you bypass the PDB and temporarily wire lipo voltage to the FC? Do you have the same voltage problem?
Threads: 125
Likes Given: 99
388 Ignore my post. But good things are working. 6S setup is pretty nice, you will enjoy it.
