Threads: 2
Likes Received: 0 in 0 posts
Likes Given: 2
0 04-Feb-2020, 07:42 PM (This post was last modified: 04-Feb-2020, 07:43 PM by Muslii.) I recently bought mobula7, and I wanted to update firmware. But before flashing I've chosen f3 version, while my fc is f4.
I tried to use impulseRC driver fixer which didn't detect my fc.
What should I do to fix it?
Threads: 595
Likes Received: 9,038 in 6,689 posts
Likes Given: 1,428
796 Hold the bootloader button in on the flight controller board while connecting the USB cable. That will put it into DFU mode and allow you to flash the correct F4 firmware to it.
Threads: 2
Likes Given: 2
0 04-Feb-2020, 09:48 PM (This post was last modified: 04-Feb-2020, 09:52 PM by Muslii.) And also device manager doesn't show it.
Threads: 595
Likes Given: 1,428
796 Try another USB cable in case the one you're using is faulty, and make sure it's a data cable because some USB cables are only designed to charge and don't have the data pins connected.
Threads: 2
Likes Given: 2
0 I used other computer, and everything worked as should. Thank you for your help.
